White Magic Fresh Tank Internal Baffling?
Newman
St. Charles, IL USA
Chris Newman
I am hoping to find a diagram of the fresh tank internal baffling. It is a 2001 White Magic 1200 pro setup with a 100 gallon fresh water tank.
At some point the water fill shutoff float freed itself from its bonds and it is now roaming about in my tank. Free yet still a captive, the dang thing keeps knocking on the walls as I am driving. I am about to loose what little of my mind is left!
I have the 8 x 8 plate off where the float valve mounts and can not see it, must be on the other side of the baffle which hangs from the top and has about a 12" gap on the bottom. Easy right? Just fill the tank to under 1/4 full so the bugger can float under the baffle, jack up the back of the van so it will seek the high point, then fish the dang thing out. Nope, There must be another baffle I can not see mounted from the bottom of the tank? If so, how high does it go?
