Mikey P said:
One with the 59 blower, do you ever dual wand with it?
Can you compare it to the performance of the VAT's
Walt Bush, I'm all ears.
We dual with it about 2-3 times a month. I tried to dual it on every job for a week but I thought quality dropped. Not because of the machine but because of my helper. He doesn't have the same eye for quality. Plus on most jobs it makes sense that one guy presprays, scrubs, spots and grooms while the other wands.
Here's the truth:
The heat is similar to a 2004
Vortex but it heats up and recovers a faster.
Suction at factory setting - you will notice a drop in suction on longer runs. However, if you put a drilled cap on the kunckle valve it's very close. The square tank takes up a less space, but there is noticeable turbulence. The result is that in dual wand mode, tank capacity drops by 20 percent or so.
With the amount of gear that you carry I would consider putting it in a box truck. You could also get a
Vortex waste tank from HK in Oregon. That would improve capacity and overall suction. You could also get the
vortex hose reel there too.
Noise level of the DXT is significantly less than a 2004
Vortex. I haven't been given the stink eye in 14 months.
Final note: If I were to get another one, I would get it with a different pump. I don't need 3k psi and would like to have more flow. It just barely keeps up with two wands at 12 flow.
