frank fratto
- Joined
- Jan 27, 2018
- Messages
- 204
- Name
- frank fratto
If you do not pre-vacuum?
Can you explain to us why?
Thank You!
Thank You!
I'm thinking about buying another vacuumIf you do not pre-vacuum?
Thank You!
They know what they're doing!!I'm thinking about buying another vacuum
Oxy-Dry and Paul both like the Hoover Hushtone
I buy a lot of stuff they recommend and they're usually right
I won't buy new I will buy used off ebay
I like wasting moneyThey know what they're doing!!
I sure like my Sanitary with replaceable bags!!
That design has not changed for over 50+ plus years!!
It just WORKS!!............
Yes get one, then report back on the performance?I like wasting money
And remember I'm a WHORE
I don't need another vacuum but why not they say it's good so I will buy a used one to try
I already have three vacuums on my van
The Hushtone will take the Sharks place on my van
Crb digs hair, vacuums pull dust better
RED PAD!!! WINS ALL DAY LONG FOR HAIR!!!!Crb digs hair, vacuums pull dust better
Yeah because having 4 dogs stuck to pad is great hahaha jokingRED PAD!!! WINS ALL DAY LONG FOR HAIR!!!!
I think, i have a really good sense of humor lol lol lolYeah because having 4 dogs stuck to pad is great hahaha joking
I thought you vacuumed it.RED PAD!!! WINS ALL DAY LONG FOR HAIR!!!!
Weren't you complaining about the cost of a truckmount?I like wasting money
Everyone should be vacuuming!? [RIGHT?]I thought you vacuumed it.
A vacuum?Everyone should be vacuuming!? [RIGHT?]
The red pad is a TOOL!
And like all great tools,
One of it function is to Remove pet hair from carpet..
I don't know anything else that works Better?
If you do please, enlighten me I'd like to LEARN???
Steve,
OVER 700 VIEW !!!If you do not pre-vacuum?
Thank You!
WOW!!!I love the art and intimacy of pre vacuuming, it lets me form a relationship with the floor and dig deep into the carpets history, learning about all its owners unique characteristics and sins as I study the real soil, soul and sole wear patterns, and not just casts of light and the homeowners recent footprints..
Once you get it wet all that valuable "stuff" gets hidden and suppressed...
WOW!!!
So vacuuming only gets the easy stuff?Steve,
After you vacuum?
A red pad pulls out stuck hair
better than anything I know of ?
Even a CRB ?
Any other solution, Sherlock??????????
Steve,So vacuuming only gets the easy stuff?
Sounds like a waste of time then.
Do you use the same vacuum job to job?
Maybe my customers are just too picky.
My wand digs out hair and mud just fine. It flushes out urine too without spreading it around room to room or job to job.
And I dont have to spend an hour a day tearing it apart and cleaning it.
Dont get me wrong I do vacuum some jobs just not every job. I spend that extra time scrubbing with the wand.
Ive noticed it does as good as the crb on most jobs too. There are exceptions though.
Detergents usually make the most difference.
My wand vacuum is powered by a 6.0 liter gm engine not a cord.it can lock down and pull carpet off the floor. In fact sometimes I do that to get airflow to help dry it.
Add 200 degree water at 5 or 600 psi for agitation and not much is left behind.
If you are not spending 15 plus minutes per small room vacuuming you are wasting your time. It would add an hour to average jobs easily. For what? Impressions?
Bragging rights?
Ive used red pads plenty to scrub in the past. Now I just use the right product.
That loaded red pad is causing fiber damage. All the sand and grit just grinding away at the soft fiber. And again cross contamination if you dont throw it away after every job.
Imagine all the poo and pee soaked into it that you never saw.
I have restaurants that I use to have to scrub to get clean. Not anymore.
So to answer your Sherlock question get a good truckmount and wand and find the right product.
Steve,Steve,
Own plenty of truck mounts for over 30 years...
Vacuuming is not a waste of time [I think you said? That you do what the Manufacturers recommend??]
No, I do not buy new vacuum for evert job?
Sounds like to me you have Great customers??
It takes me about 3 minutes to tear apart the Sanitary??
Wand SCRUBBING???
CRB VS wand " for SCRUBBING ?? "
Detergent makes all the difference??
Suction Carpet off the Floor "omg" That's when MUD MAKERS have a problem??
If you're charging correctly, 15+ a room is part of the JOB??
Carpet fiber is very TOUGH, you Vacuum to get the Grit and Sand Out? [YOU MUD MAKER]
Using a RED PAD almost every day for 10 years, NEVER DAMAGED CARPET YET??
Red pads are very Cheap??
Yes I hope all the poo and pee soaked into it??
Steve,
Thanks for all the Good Advice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
