Who will win the meAt off?
RV360i VS 175
  • Total voters
    15
one ten by ten of Section 8 Lasagna...
One Sapphire Truckmount..
One 1.5 HP 175 floor buffer and a fiber pad..
One RV360i..
Two broke dicks with two hunnert bucks on the line...
one Geezer with 360 Viagra pills...
San Francisco, CA
I Thought it was a 175 followed by a highflow non glided or slot glided, versus the 360i.
And off course MeAt!
Cause he is much less easily excitable !gotcha!
Well Ofer, if you were not so excitable you would have seen where I wrote ONE SAPPHIRE TRUCKMOUNT and used your deductive reasoning to assume it would be used to rinse the carpet.
and I'll try and contain my excitement when I rub my winnings in your face.
Mike Draper
Meat, get ready to pay up sucka!!!!!! I'll take the $100.00 now if you want to back out early without the humiliation. :lol: :lol:
San Francisco, CA
See what I meant about excitable.
And does one have to be actually present to have his face rubbed in the winning?
Personally, I'd much rather you sent it :roll:
Art Kelley
Clawson,mi
Well, I'll just have to take Mike's opinion about the 360i until I see for myself at Next year's MF. I wouldn't bet against him. I do know that a much heavier low speed RX20 just could not clean as well as a 175 with a brush followed by a wand; something I compared for a year in 1992 until I finally put the RX away for good. And this was using a 14" 1 1/2" wand with 6 flow. Using my Ti wand with GG and high flow would Really kick the RX to the curb. I can't see why the 360i would be any better.
San Francisco, CA
Did we forget to mention that MeAt is an arm dealer? shiteatinggrin
Brian R
Little Elm, TX
Brian Robison
Can't we have a side side bet that neither of the two idiots doing the cleaning will increase their manhood by cleaning "better"?
Good God Girdy. :roll:
San Francisco, CA
Brian!
You may be suspended for un mikey board activity!
You've been warned :p
XTREME1
Ma
Greg Crowley
Just have one impartial person such as me do the cleaning with both methods
adamh
Nampa Idaho
Adam Hale
The results will be close to the same if the equipment is ran correctly. However, the RV will do it faster and WAAAAAAAAAAAY easier!!!!! Faster because you aren't dragging the 175 out of the truck.
XTREME1
Ma
Greg Crowley
Lesser men drag the 175. I find cleaning with the 175 quicker, less spotting, you don't need spend the additional time grooming and edging. The RV 360 you have to just about edge the whole place which done properly takes up more time than the prescrub
My guess is that the results will look about the same. I don't think either party will be paying out in the end. So I have not voted.
Truth be told for most cleaners dragging in a 40lb tool makes more sense than a 100 lb tool. My 80lb RX-20 is heavy enough, and I've gone back and forth on taking it out and it's mostly because of weight. Anyways clean is clean, I think you're at the point where it doesn't make a difference when you have good mechanical agitation.
Like i said, we'll let the chips fall where they may
I figure the end results will be close.
I'll be looking for an evenly soiled salvage rag.
I figure I should be able to find a dandy sample between then and now
til then, ya'll can pound your chest and flap your gums.
I'll just show up and do what we do everyday to restore salvage rags
Art Kelley
Clawson,mi
The results will be flawed and non-real world because you will not have to edge with a wand all around the loose carpet as you would in a normal room, substantially decreasing the time (and PIA factor) you'd normally spend using a rotary extractor. No one will win the bet if the 360i can indeed come that close to the 175/wand combo.
meAt, bring only sections that are embedded all the way to the scalp.
we'll cut it up into two equal sections, weigh them each, let them dry and weigh again
and trust me, there will be a clear winner there.
Erik
Michigan
Erik
Larry can use the Zipper if he wants. And I have two hundred on it.
Erik
Michigan
Erik
Mike u may change your mind by next week. :lol:
that's just dumb chit there.
Did Tony teach you that or the rocket surgeons at SOA hEdquarters ??? :roll:
a strip of tape down the middle.
You on your side, me on mine.
everyone will judge by appearance
only hacks get by on appearance Larry.
lets Wernerize that rag and show these rookies what clean really means.
I realize your client base is content if you get the Po' chop and mounds of dog shit unglued from their dirt floors but in my world they actually walk around with white socks and crack has not ruined their sense of smell.
don't be dumb
the weights and measures thing won't tell much..and that's for gEEks anyway
Too much variation .
Your side could look like chit buy weigh less cause you yanked a bunch of fibers out
I don't care if we warnerize it or not, but the thing will be so abused, we'll be vaccing latex out before we remove all the dry soil.
lets keep it real world...or are you starting to back peddle now???
you forget I've ran the 175 with 18 different colors of pads and shampoo brushes and Greenie, Ti Evolution, Stryker and Mytee wands and Zippers...
and ran the RV..
while you have NOT :!:
you have a drag wand, a TI and a junk pile of 802's to your name...
still time to back out bud.
what for??
hell, i don't have anything to lose...I already said I've never seen one.
It's YOUR reputation that's on the line, not my hunnert
you use pee water calIfOrnIa approve chems and haven't had anything but a poor cleaning hole or hybrid glide on a wand since you left Coit.
the RV is the first time you've cleaned with a slot in forever
I'll be having fun...YOU'LL be sweating... :lol: :lol: :lol:
Dallas, Texas USA
Hey Mikey;
You are going to use the Brush Head on the 360i, aren't you.
I think it cleans very well,
but I have not tried it side-by-side with a 175 and pad;
After a uniform prespray.
Larry
