Why would a carpet ripple after the fourth time I've cleaned it over 5 years?
ImperialCC
Jason McCurry
on the other side of the house, that recently had new super thick granite counters AND a swimming pool installed, a 4' grout line on the master counter popped loose ON THE COUNTER, not in the backsplash joint.. wtf
The whole place shifted to some extent
Is the place going to fall in the ocean when California goes in? You better move east. Maybe even to Alabama!🤣🤣🤣
  • Haha
Reactions: Nomad74
JHK
John
This is what we email our clients if that ever happens.
Post Cleaning Ripples on Residential Carpet:
There are a few things that are causing your ripples. First, residential carpet is rarely installed correctly these days. Most installers only use only a "knee-kicker" to install a carpet even though the manufacturer requires that a "power-stretcher" be used which provides a "tighter" installation. Because of this, it is usually is a little loose to begin with. It might look fine to you, and it might lie flat most of the time, but it probably does not have the needed tension. This is contributing to your problem because just a little bit of expansion on your carpet will cause a major change in appearance. The main cause of the problem though is the carpet backing itself. Carpet manufacturers use clay as a filler in the latex backing. When this backing absorbs moisture, it will expand. So, when the clay in the backing is damp, your carpet is actually expanding. This will cause wrinkles or ripples to appear on the surface. If a manufacturer uses more clay than average in the backing, the problem is more noticeable after cleaning.
Most of the time, to remedy this situation, you simply need to let the carpet dry completely. Once it is dry, it should go back to normal. To speed the process, use fans and/or heat to help dry the carpet to lower humidity levels.
If the wrinkles are still present and you are positive the carpet is totally dry, then you will need to contact a carpet installer to come out to properly re-stretch your carpet using a power-stretcher. (this would be at your own expense do to the fact that the carpet was not installed “tight” enough in the first place or loosened up over time from usage and wear). Karastan, one of the most respected brands of "high-end" carpets in the world mentions this potential problem in their installation guide that requires "power-stretching" This is a quote from their guide: “All installations must be power stretched. After seaming, the installation must be power stretched in all directions. “This helps prevent buckling or wrinkling and provides greater stability.”
Reactions: Living The Dream
sassyotto
Paul
I had that once, cleaned a carpet a couple times prior which was just a tad loose, then got my new Titan 575 and wasnt familiar with the heat settings and probably was too hot. Carpet rippled but went back down again.
Swani
I tried a new coffee this morning called Black Rino. I thought I was ordering Black Rifle, but no it;s Rino. It was a bit stronger than my normal foo-foo flavors. I liked it.
That is all.
Black Rifle is some good stuff and the owners are very good people.
Reactions: Nomad74
