Wicking fixes????
Rescue
I have wicking issues.....Do not know what it originally was. It cleans up well with JJ, but keeps returning. What do you think? Hit it with the Claw until it is bone dry? What product works best for you?????
Rex Tyus
It depends on whether you actually want to clean it or just seal it in the backing. If seal it in the backing then take your pick from the above advice. If removing the source is your goal, then use the claw as you first mentioned. Soak scrub dwell and flush like hell and extract.
alazo1
San Jose, Ca.
Albert Lazo
To add to Rex's, get the homeowners fan and leave it on the area. Preferably a fan you can tilt down. Set on high, tell ho not to walk on it for the rest of the day, cross your fingers.
Albert
first off, is it wicking, or a recurring spot?
wicking happens during the drying process and is there the next day
recurring spots are gone the next day and return some weeks or months later
Clean it again apply 4 or 5 paper towels on the spot and put something fairly heavy on it,,like a telephone book, the spot will transfer/wick up into the paper towels and ..its gone ..bye.
John Watson
Like Larry said, Wicking is during drying, If you leave it bone dry it aint wicking..... Reoccurring spot means there is still some residue that is attracting tracked in soils.. Means you didn't get it all..
Now go and "Git er Done"
cu
San Lorenzo Ca
Cu
if you have gone through all the above
lift the carpet switch out the pad put in some new and move along
Use a claw if it is a specific spot or two,otherwise try an acid rinse.
How big of an area is it?
Sounds like more than a few reoccuring spots?
Not likely from the JJ....unless you rinsed with plain water and didn't use the O2 rinse agent...It's always possible to leave some prespray by mistake.
