Will my equipment do the job or do I need a...
Noidios
Russ Zinck
I currently do carpet for a large property manager and they would like me to start doing some occasional T&G. Just wondering if I need to be a Spinner or a Turbo hybrid, or whether I can make it work with any of my current setup.
Cimex w/ brushes
Rotovac Powerwand w/ brushes
13" and 17" rotaries
ProCaps CRB
Manual grout scrub brush on a pole
Evolution wand
Plenty of airmovers
My truckmount doesn't give great heat over 600 PSI and starts spitting water at about 100 PSI.
What are my (cheap) options?
Gary T
You can do it with what you have. Mop the cleaner down, dwell, scrub with the grout brush (rotaries just aren't as effective getting INTO the grout lines), rinse and extract with a glided wand.
Brian R
Brian Robison
Looks like you will be able to do it buuuuttttt.....
If you get serious about it, get a turbo hybrid.
Makes life easier....although I think it won't work well under 700psi.
I would make sure your able to use it before buying it but it has made me WANT to clean tile and grout.
Well I do T&G with a pressure washer, inline pressure control/restrictor guage, and t&g wand; http://www.***************/store/mytee- ... -4914.html ; and propane heater on my recoil; i think u got it covered but no replacing a good t&g wand.
