Will scrubbing with a 175 and brush damage cut pile ?
P
Paul Demers
I am still new to business, and confused about the use of a 175 with brush to scrub residential carpet.
Mikey says he uses his 175 to scrub on almost every job. George Vallient says scrubbing with a 175 brush will damage/distort carpet fibers.... unwind the twists in the yarns.
I would tend to agree with George...I would think that a 175 scrub brush would be way too aggresive on residential cut pile, but what do I know... being a new guy. I currently use a counter rotating brush, which seems to work well.
I am open to the idea of scrubbing with a 175... but certainly don't want to damage carpet fibers.
joe harper
joe harper
Paul,
If the carpet is in such POOR condition the you need to SCRUB-it...... :wink:
Chances are the warranty has been VOIDED already... :!:
As long as you Put down enough PRE-SPRAY.....You will have no PROBLEMS.....
You will do NO MORE DAMAGE than a commercial vacuum.
Just make SURE you keep the fibers DAMP...Damage CAN occur if you run the BRUSH
on DRY FIBERS.... :wink:
got a point.
Wasn't one of the reasons people were against bonnet padding was the untwisting of the yarns?
That was with a pad, would a brush be better or worse or the same?
