Winter Gremlins
C&S
Scott
its a "Bedrug VRF92 VanRug Cargo Van Mat" got it on amazon for $150ish
juniorc82
Jon Coret
Waldo for as many problems as you have had with that lg, I would replace it with a northstar diesel heater. I have had no problems with mine, you can run higher pressurean flow . Also no more dicking around with regulators and al the other lg hassles. 1500 bucks to your door
g
Royal Man
Dave Yoakum
g
Do they hold up to being frozen? That seems to be the culprit.
My banana tree needs a space heater. The leaves are getting sort of brown around the edges.
Maybe Ill park the AT by it tonight and let it idle.
It's cold there? I was planning to run on the beach, get a tan, go surfing? :cry:
:winky:
juniorc82
Jon Coret
Ive never frozen mine, but it is rated for more pressure and flow and I know the coil is a lot more heavy duty than an lg. I also like that you put your kero or diesel right in the unit in a fuel tank. no more dicking arourn with propane tanks. No need to take the thing apart twice a year to clean the burner either. All you do is run a splash of fuel treatment through there and it burns all the soot off the burner ring. If he has a box truck this would clearly be the way to go. Its rated for like 4000 psi. I cleaned tile and grout once in a commercial kitchen at 1600 and 220 steady it was no punk
Maybe he should just sell that POS and go heat exchange? He could quit fooin around with a secondary fuel source and heater then.
Run some winter washer fluid in it or compress air blow the system and just use a heater when it gets really cold. ???
Build a garage?
