wiring a apo with float valve
wilpath
hi there, i got a hypro d 30 , i just rebuilt, great pump out btw, i also have the hartwill float valve ( same used in the waste tank), i have the fitting in the waste tank ( prochem 100 gal waste tanK),
my question is how do you wire the pump to the float valve to the switch so that it runs on auto???? thanks in advance, a video or pic will help,,,
the float switch is just like a light switch....power comes into the float...float lifts up and closes connection and sends power to the APO....
so...power to the float.......and then...out from the float to The APO...you should put a fuse in between source and the power going into the float...
run a ground from the APO to what ever ground you may have....
Or...
run the power straight to the APO..then run a ground to the float..and then from the float to the APO......
either way...make sure you have a good ground.....
Spurlington
Spurlino
you may wanna use shrink wrap rubber thingy if connecting wires for under water .. forgot what you call it but you use a flame to shrink the rubber tube over connected wires
