type of carpet, type of
glide, and depending if you are on a wet stroke or dry stroke will affect that reading as well.
I know when Michael Schoeny was at the house with his SchoenyTech, we had about 100' of 2.5 out, 25' of 2" and was using my 5 port Vanifold at the truck, and hole glide on wand, showed 13-14"hg when cleaning with 018 flow, under block off the relief valve was set at 17.5"hg....but there was so much rippin' through the wand it only showed 13-14 on the gauge.
That number
drops to 10-11hg when dual wanding, and it "feels" like it's sucking
harder for sure, actually I'm pretty confident it dried the carpet just as good if not
better in dual wand, so there is something to where that "extra" air is coming in from, either the vacuum relief or the second wand, that impacts overall vacuum efficiency.
I made a special Vanifold with a vacuum releif valve mounted
on it for him to test this theory, it allows relief on the other side of the tank (duplicating dual wand) when single wanding, haven't heard back yet, but will report when I do.
