Wool/ Silk rugs cleaned on location
You should be able to see why these rugs wont be sent out for cleaning..
I have my plan of attack but would like to hear other's ideas...
boarders and highlights are silk..
4conlUFCesIAVFVMoBwGV0aw1nqG9GgW9iPL3TmJMzOVc_LWd2sU5Y6c3_zmX4QoWhUatOhdl2gQ6Z2vhD=w1698-h955-no.jpg
_oPr2YAbKNNHcP3uFd_ETXAwtTvVxM8y2D_22NsAtrKUMW0MAD2qHYJkMg1cvFTuTQAK4d5pS2Wd7Zeh68=w1698-h955-no.jpg
O_sU3ml4WV_HU_WRtPEQNtRbWsTG46_yfpYbJSbqW3UI53NQUajfvaQTTFnut1GJJg096NGSSYSUdybM5NL=w538-h955-no.jpg
OBaMNAxzZBJRNrJVIQDp7SFSzAqEGuA-I2sKxwhWQ8xrooz_cZrU3H8RuWjwc_cut0YnkFQ2U5eA0U1ISQ=w1698-h955-no.jpg
gQ9r7aYvTqxLw9Vahtq1dcfUwdMpn5XyU8zPUKQiQ0st2UsJDpZkR0xFDN80sGONjQPUmTQoEO-8-z-x1T=w1698-h955-no.jpg
bbBlqWaRgnbPq2VaGLjiZjgTMror0A39K6i6RkEaJyWq6yfBGDWzoqieaTb1J_muaaRisxJpLCLIaWe7gc=w1698-h955-no.jpg
wool and leather trim
hiAP1m3fde4OG3SACq7sE7tA5E0opXQKYoirWmM0QiGyAICxNy6g5FPMn0PjC-yyYgPDHedC-y9oni6rzv=w1698-h955-no.jpg
Job is in The City..
O4_UcyLdmOTWjYrLh9L6xERlrB9jSOj7ANlLs5Drt46KsfTC-j-YNq9OQxUSDSiXg1BNTUaXNLqJzxthlH=w1820-h955-no.jpg
Kellie Hiler
Georgia
Kellie Hiler
I've thankfully never run across silk or leather on rugs and I'm not sure how you can clean it but I would imagine it's going to be very little to no moisture?
Or with a fine fabric prespray and an upholstery tool?! :shifty:
Reactions: Lee Stockwell
There are lots of woolsafe products you can use. No heat on silk, you may cause it to mat. Biggest problem is that you leave wet rugs on the hardwood floor. Encap with a brush pro if the rugs will tolerate the agitation.
Kellie Hiler
Georgia
Kellie Hiler
That would be my concern is the heat, so if it were me, I'd use a portable with the UPH tool.
As for the brush pro, I'd be afraid!
N GA
BradFenstermaker
Hose dat peewool down with acid prespray. Drop heat a bit and steam it.
Few extra dry strokes and groom.
Give the pooch a treat. Collect payment.
Scott S.
PA
Scott
I just had a customer contact me friday about doing some wool rugs in her home, and some silk ones that she doesn't want to leave her house. i have to go inspect before i agree to anything. the wool i got covered but the silk ill have to inspect heavily before i agree to anything. ill take pics if its anything special enough to show you guys.
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
I'd go a low moisture route. Encap using Brush Pro and Encapuclean Green or Encapuclean O2 to brighten the white. When diluted per l;abel directions, the encaps with peroxide are not potent enough to harm wool or silk. Could also use the Brush Pro Dry Powder.
Dave Rampage
we have a customer that has a wool silk blend and it was trashed. I told her i'm not supposed to agitate it but thats the only way to get it clean. I told her if she was willing to take the risk I will give it my all. She said ok because the only other option is replacement.
I sprayed it with Procyon, scrubbed it with a cimex then extracted. It came out like new. Now have customer for life.
Reactions: BLewis and Mikey P
GeneMiller
Boca Raton
gene miller
I tried a silk rug years ago and basically ruined it. It was turned into a door mat so she didn't care. I won't clean pure silk in the house any more after that. I'm a quick learner.
Plastic painter tarp underneath
Brush Pro with soft bristles
Royal Vac
Tepid water
Prochem Fine Fabric applied with a Multi Sprayer
Some form of lite agitation (will need to test each piece)
Extract silk areas with SS Uph Pro, Mach 12 the rest
Aerotech on low setting
Velvet carding brush groom
Fan dry
FPA application if aproved
Reactions: J Scott W
I can't think of any thing your missing. I think you are good to go. I usually use painter's canvas drop clothes instead of plastic. I use the Prochem fine fabric in the shop, works beautiful.
BRAUN Brush sells a carding brush for rugs that is more than twice the size of the normal velvet carding brush. The work great for carding rugs or you can use without a handle and finish velvets in half the time. I love it for upholstery. :cool:
