Would a Zipper..
Ron K
solve the problem I;m seeing with a lot of Commercial work lately. I don't do much commercial at all but the work I see looks like shit. First off for the first couple of years they are cleaned using foam and bonnet and just over chemicaling IE (CAC). Then they call a truck mount guy and it still looks like crap. Then they call me and I say you don't need cleaning you need restorative cleaning not just steam cleaning. I see a lot of overlap cleaning meaning where the wand strokes overlap theres a clean line. It looks real bad. Would PC,a 175, and a Zipper take care of the problem on CGD? They do seem to be vacuumed well.
Erik
Michigan
Erik
Are you talking about the overlap between cleaning sections? Years ago when using under powered machinery the lines would wick. I think they are called Zebra stripes. If so the answer is yes.
Covert
Marcus
Ron ....need to know more detail about your equipment...
Is it a teuckmount...what is the engine size..heat and blower size....
I do a lot of resturants for 12..14 years ran into just about everything..but you gotta have the right equipment
Thanks bro
Cap
Ron K
I 'm not the one doing the work yet I think the work was done by someone with a pretty large TM. I my self have a 20HP Legend I would only be running about 100'.
Erik they seem to be Zebra stripe but clean lines not wick back.
Boca Raton
I call it railroading but the same thing. It's from an improperly set up wand and or lack of knowledge. The biggest advantage is you can't screw up with the zipper if you keep it moving. Not true with the wand especially on olefin Berber in a house or glue down. It will let you flush better because it won't lock down easily on glue Down. The biggest problem on commercial is lock down which now means you are no longer removing water or soil. The bigger the blower the worse lock down is. The proof is in the wicking. The hoss has slots in its shoes to prevent it. Your wand glide needs cats claws and it will work better on glue down. A utility knife will make nice clean vees.
Gene
Reactions: Erik
Covert
Marcus
Don't know if you are doing a restuarant? But you gotta have heat..kero is my choice......
If it is just regular commercial carpet the zipper will help but you may run into some problems without enough heat On some of these grease pits.
Cap
you've been around long enough to know it's the man, not the machine, Ron
what you're seeing is just what Gene alluded to....a clueless mOOnpie on the end of the wand
your restorative plan sounds like a sound one to me.
I haven't had the pleasure of using the Zip, but used drag wands for a lot of years.
one man on the roto scrub, one man on the drag wand, and you'll restore a lot of real-estate in a most efficient manner
Reactions: Ron K
