gimmeagig
I just did a search, couldn't fine much.
Which is better?
Which is better?
What? Hydrocide or Hydrocide Extreme did not get into your competition?
These products all have the same active ingredient. IMO, the biggest difference is the fragrance or lack of fragrance.
Roxy;
There are better values in the market.
Scott's product and our Dynacide are both less expensive.
http://www1.cobbcarpet.com/zen/inde...sult&search_in_description=1&keyword=dynacide
Larry
So what is the active ingredient in all of them??
Dilution ratio and trust and supporting the distributor that will support you. You asked for an answer about two products, if you want the cheapest then forget all those and buy onslaught from steam way it is $28 a gallon and is every bit as good as any of them but when you figure in the dilution ratio it cost about the same. It was our number one seller before odorcide it would still be but most of my customers can do math and odorcide works at 4 oz per gallon for REAL which cost less then 24oz to a gallon to get most others to work. I tried to not go down the road of trying to sell, just answer your question. Call me up and buy a pint $15.40 of odorcide buy a gallon of onslaught for $28 buy Larry's and interlinks and ill give you a gallon of anyone you think beats either odorcide or onslaught. I guarantee neither of them will beat either of those two products. X-Cide isn't a bad product you just have to use way more to get the same results.Bridgepoint Hydrocide 80.-
Odorcide 80.-
Pro's choice X-Cide 80.-
Dynachem Dynacide 46.- (that is substantially less)
So if it is the same ingredient in all of those products(Zinc Salt) I can see why they are all the same price.
Is there less Zinc salt in Dynacide and is that the reason why it is less expensive?
Is there any other reason why i might choose one of the more expensive products. And are they really all the same aside from the fragrance?
John Olson" data-source="post: 4235910" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Dilution ratio and trust and supporting the distributor that will support you. You asked for an answer about two products, if you want the cheapest then forget all those and buy onslaught from steam way it is $28 a gallon and is every bit as good as any of them but when you figure in the dilution ratio it cost about the same. It was our number one seller before odorcide it would still be but most of my customers can do math and odorcide works at 4 oz per gallon for REAL which cost less then 24oz to a gallon to get most others to work. I tried to not go down the road of trying to sell, just answer your question. Call me up and buy a pint $15.40 of odorcide buy a gallon of onslaught for $28 buy Larry's and interlinks and ill give you a gallon of anyone you think beats either odorcide or onslaught. I guarantee neither of them will beat either of those two products. X-Cide isn't a bad product you just have to use way more to get the same results.
Odorcide 80.-
John Olson" data-source="post: 4236029" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Thanks John,Poor information and not true. Think of the frebreeze commercials with a the dead fish and garbage. Sure you can't smell it but it is still there. Call me tomorrow and ill explain it more but he is wrong and giving bad information probably because he just doesn't know I hope.
OK Jimmy, so what do you do in a severe case like I had? Do you have any tricks up your sleeve?ZINC SALT =CHEAP...............PRODUCT EXPENSIVE............?
I checked on that basement room and it's a lot better but still there is a lingering unpleasant odor. I went over it one more time with X-cide (I had samples for that as well) and it was nowhere near as effective as the Odorcide.
So when that wasn't doing anything I ended up spraying the carpet with Molecular modifier and also injecting it into the pad. It appears that Odorcide is not a silver bullet that can replace all other odor remedies.That would have been too easy!
That job may have been beyond what carpet cleaning can do.The carpet in the basement (or at least the pad) should really be replaced, who knows how deep the urine went into the pad and the concrete slab,but the owner is trying to sell the house and doesn't want to spend the money on replacing anything.
Being such a simple and cheap ingredient like a ZINC SALT, then does it contain any other compounds like diamonds or GOLD to make the product so EXPENSIVE?
