davegillfishing
do you want machine shots or just exterior shots..
"The Zerorez truck has an on board heater which can heat water to 350 degrees F...
The Zerorez vacuum has about 12 – 15 times the lift of a typical truck mounted carpet cleaning motor, so your carpets dry more quickly and thoroughly."
Erik said:WHAT'S UP YOUR SLEVE??
