Lyman
- Joined
- May 19, 2007
- Messages
- 1,765
- Name
- Lyman
I have a 13 inch bent handle zipper. I would like to upgrade to the 15 ss. Can I buy just the new head or do I need a whole new zipper.
I think so. We use the Spinner far more than the Standard. Although I saw them using the Standard today for the first time in several months.
Take a stand, 10,000 lakes man.
Which is better, or where do each excell?
Since the SS seem (according to Grasshopper) to use about the same amount of water as the regular, and since it is better with heavier soil, why not use the SS?
Is it slower?
Any other reason?
I feel like I've hit a production plateau.
A rotary is perfect for a 1 man show.
But now I have a helper. He watches quite a bit, when we go with the rotary. I wish we could take a Zipper out for a week. I think it might help us break through a little, and push our production level noticeably up.
Hey Mark, does it take longer for your crew to CRB or Zipper a particular area in a home?
Just wondering if your Zipper guy is waiting around a lot for the CRB guy...
Nate, you do now you can adjust the wheels so it will push easier......
This always baffles me but I know it is polarizing.
An inch or two seems to really bother some. Maybe it's how we clean but we move most furniture. So size isn't a problem even with furniture.
I do cut in around HVAC vents and doorways. Everything else gets the Spinner.
It doesn't appear to leave it any wetter than the Standard Zipper, so why not flush it good?![]()
How many guys use a regular Zipper in residential? I'm thinking of getting a 15" Zipper SS, as I may be targeting a lot of restaurants for several months (alongside residential) as low hanging fruit to get our business off the ground when we move to a new populated area sometime later this year...
Once I get a Zipper will I probably want to use it on empty houses and apartments too? Is there any reason why you cannot use the SS in residential with cut pile carpeting? I cannot afford two right now, so I want to pick one wisely... So, Zipper or Zipper SS?!
I strongly suggest you go out and clean with somebody for a day or two with a zipper before investing..
It's not as easy and fluid as Saiger ('s kid) makes it look
