Zipperwand & DwellPro
dwellpro
m
I'm about to have 3 Roto-vac xl's and 3 360's for auction. Done with them.
dwellpro
m
Two of them are being fixed by Roto-vac. I will put them up for auction when I return from hotel cleaning on the East coast.
I am running a 9 flow on a 15' zipper w/85ft of 2" hose.
I have a 6 flow 10" that I run with 100ft no problem...
The new Dwell1-H has 1000psi w/dual 600watt heaters. Made to move mountains! Or atleast a lot of soil.
rjwood
Faux Fosythe
Me
One issue that concerns me about going directly from the tap to the wand/tool is that prevents using a rinsing agent. Do you ever see a need for a rinsing agent? Or have you incorporated feed for a rinsing agent?
I believe you may have meant 13"....
His machine has a built in dema injection system fur rinse agents
rjwood
Faux Fosythe
Me
You mean like a pressure washer? Those can be rather finicky.
Very smart design for portability, but very expensive for a portable.
JS41035
I'm swimming in turbo hybrids right now. I'd be interested in a 360 or an xl. Maybe take it in trade on one. Plus some cash.
dwellpro
m
A second Dema can be connected at the faucet if desired. Rinse can be added here. The Dema I use is not the ones used for power washers. It is called a Dema Mixrite and it is water driven not motor driven.
You get what you pay for with Dwell Pro machines. The price is actually on the low side when comparing components used.
dwellpro
m
Here is the Dema Mixrite. Please notice the price. Nothing is inexpensive on this machine. Built to last well into the next generation...
