What have we got here?... 2015 Sapphire Pro 1200 unveiled..
Arizona
if you have a good filter box...that is the best and most simplest way of doing it...
with out a filter box then your going to want a devastator .........
I did not know that they had filter boxes or or I would have gotten one for my 570.......
Zee
SoCal jungle
I'd be a lot more interested if they built this for the new euro style vans... Any plans for something like that?
Reactions: Cleantechsk
Sapphirerick
Arizona
Rick Aranda
I'll start with the basics as I'm using my cell phone and it's a little difficult to go back and forth. It is a T408 Heliflow blower. This is the same blower we use on our 570.
The water pump is the Emperor series By General pump. 5.6 gpm. Max psi is 1200 psi.
The clutch we use is rated at 120 ft lbs of torque.
Waste tank capacity is 80 gallons at shut off. There are two ports available to add an APO if needed.
NY
Ralph Pastorelli
My old 1200 had all day water and waste tanks of 120 and 140 gallons will a bigger water tank be a option?
