Do you have a hyperlink and/or model number for this more accurate meter? Do you know what the approximate cost is for one of these meters if I were wanting to buy one for myself?Dan;
As a user of several flowmeters, I did question the pressure drop spec and pressure deratings.
However, when I checked it against my more accurate sapphire-bearing 0-20ma industrial flowmeter, I found good accuracy and minimal effect of pressure drop.
My new model will also be calibrated before I do any further testing.
Thanks for your concern.
Saiger" data-source="post: 4558522" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Correct....it didn't work and we tried a number of different machines, wands, hook ups...
Maybe we just didn't have some magic skills
Mark, Did you use this type :
If so, the only issue we had in several days of testing, is debris getting into the flowmeter. Long yarns or particles ~ 1/8" can lodge between the moving parts and stop the movement, since it is made for air only.
Not sure how accurate it will be but it should tell us how each wand compares..
Lots of room for error there Larry. If one person dances thru 500sf in 1 hour, and 2nd person spends 2 hours, it only stands to reason the more time spent on dry vacuuming after extraction would recover more H2O.
A better way to measure the "resistance" of a wand, or its flow, would be to blow air through it and measure back pressure.
BS Larry.That doesn't take into account the "airflow thru the carpet fiber".
In our testing we put 10 lbs of weight on the wand head to simulate slight down pressure,
and then pulled the wand horizontally only, on the same type of carpet.
I think Bristor and Larry should hold a public debate on youtube speaking on CFM. Pig farmer could moderate and keep a fight from breaking out. That would be awesome.
BS Larry.
Measure the WAND. Exclude other variables.
So what exactly are you looking for in all these tests? Is there an overlying hypothesis that the cfm data will prove or disprove?
