Flex Ice on Smart Strand Polyester
Discussion in 'the CleAn Room' started by Johnny, Jul 27, 2017.
  1. Johnny
    Johnny
    Oct 22, 2006
    2,078
    Ventura
    Name:
    Johnny
    Presprayed Smart Strand Silk (poly) with 2 oz / gal. (4 oz in small area), Flex with Citrussolv. Rinsed with Flex Ice at recommended dilution. Customer called a few days later about residue on her Dyson. I cleaned the scum off her vac and recleaned with the same chemistry. A few days later, customer complained about stiff carpet, so I performed the mother of all rinses (MOAR) with Fab Set, which left the carpet soft and visually clean. She called yesterday (30+ days later), about new scum on her clean vacuum. She is not trying to jerk me around. I need to understand what is causing this, not only for her, but for myself.
    I've cleaned hundreds of polys with Flex prespray and Ice rinse. Are some polys more difficult to rinse? (More oleophilic?) Is it possible that Ice doesn't have the emulsifying muscle to rinse this particular poly? Is Ice leaving residue?
    She says the previous cleaner didn't leave residue, but she didnt call him back because he was sloppy and didn't prevac, prespray, or scrub. I'm guessing he didn't even know the fiber, but hit it with the same alkali rinse he uses on everything else, which was, by chance, appropriate for this fiber.
    Im thinking my next approach should be a mild alkaline rinse (Point Blue, Pro Max, etc.).
    She also mentioned the carpet is matting. I believe this is typical of Smart Strand.
    Much obliged.
    Steve Lawrence and Matt Wood like this.
  2. hogjowl
    Feb 19, 2007
    27,033
    Prattville, Alabama
    Name:
    Marty Sutley
    I'd be asking if she routinely uses carpet powder
  3. Johnny
    Johnny
    Oct 22, 2006
    2,078
    Ventura
    Name:
    Johnny
    Thanks for the reply, but she doesn't use powder.
  4. Onfire_02_01
    Onfire_02_01
    Jan 2, 2016
    724
    Minnesota
    Name:
    Jeremy Gray
    I was thinking the same thing. I am no guru so maybe someone else has ideas but something doesn't seem right to me i.e. a little fishy.
    Matting carpet is typical and unavoidable with poly over 2 years old. It is the weakness of this fiber.
    If I were called back for a foreign substance on the carpet I would have opened up the fibers at various locations to check if there was anything sitting on the backing of the fibers that was similar to the vacuum buildup.
    No matter if you used ice or some other rinse there is not enough rinse material there for a buildup of that amount. You have at worst 3 cups of rinse into five gallons of water which is then diluted to 2-4 gallons per hour. To get a residue on her vacuum cleaner you would have had to spray out 2-3 gallons of rinse onto the carpet and not extracted any of it back out. "I assume you are better than that."
    There is my dollar of advise. Wait does that make me a guru now? :biggrin: :clap:
    encapman, Jimmy L and Johnny like this.
  5. Johnny
    Johnny
    Oct 22, 2006
    2,078
    Ventura
    Name:
    Johnny
    White carpet fibers and backing looked completely clean after last cleaning.
  6. Mikey P
    71,817
    Name:
    Mike Pay-oh-tay
    Lee Stockwell likes this.
  7. steve_64
    7,188
    Just a guess but you may have loosened the oils in the fibers but not removed them completely.
    Oils are used in processing the fibers and are not completely removed during the process.
    Try an olefin cleaner.
    Johnny likes this.
  8. Matt Wood
    Matt Wood
    4,451
    Georgia
    Name:
    matt wood
    I remember Scott making the comment when flex ice first came out that you need a water softener to use ice
    Is that still true?
    Mikey P likes this.
  9. Ron K
    Ron K
    Jan 3, 2009
    1,865
    What does the residue on the vacuum look and feel like? Can you replicate it with something? A back of a spoon rubbed on the carpet? Scrap the residue off the vacuum and see if it can mix with water? Do the brush rolls have residue? Does she use any spotter heavily?
    Johnny and hogjowl like this.
  10. ruff
    9,205
    San Francisco, CA
    Name:
    Just confiscate her vacuum. As far as I am concerned she lost her vacuum rights.
    Reminds me of a client that called me the day after the cleaning and told me (I kid you not) that- "she woke up in the middle of the night and looked with a flash light under the bed and saw brush marks."
    After a short stunned silence (does not happen frequently here) I regained my senses and told her that- "She should not look with a flash light under the bed in the middle of the night."
    She's still a client.
  11. Johnny
    Johnny
    Oct 22, 2006
    2,078
    Ventura
    Name:
    Johnny
    I have a water softener.
  12. Johnny
    Johnny
    Oct 22, 2006
    2,078
    Ventura
    Name:
    Johnny
    Residue is a grey powder. Dissolves in water. Residue on brush roll.
  13. scottw
    scottw
    Oct 16, 2006
    2,665
    West Jordan, UT
    Name:
    Scott Warrington
    I can't imagine Flex Ice or any other rinse, when used properly, leaving enough residue to be seen on a vacuum brush roll. The strongest rinse dilution calls for 1:320. Flex Ice (and many others) is 1:640. After extracting most of the rinse out, there should be a small fraction of a spoonful or less left behind on the carpet.
    If the carpet is rather new, a year or so, Steve's comment about loom oils is valid.
    Something is probably getting on the carpet from a source totally unrelated to cleaning. Pollution or dust in the air or such or the powders she claims not to use.
    Lee Stockwell, Johnny and Jimmy L like this.
  14. Jimmy L
    10,857
    Name:
    She will always be a problem customer
    Jim Pemberton likes this.
  15. Old Coastie
    4,908
    Heart of Dixie
    Name:
    Housekeeper scattering deodorizing powder?
    Mikey P, Mark Saiger and scottw like this.
  16. Ron K
    Ron K
    Jan 3, 2009
    1,865
    I'd wash off the residue from the brush roll and see how long it take to come back?
    How do you really know it's from the carpet? Does your brush roll have the same effect?
    Also "grey" "lady thats my hair and if you keep calling me about this I'll loose the little I have!"
  17. Johnny
    Johnny
    Oct 22, 2006
    2,078
    Ventura
    Name:
    Johnny
    Carpet is less than three years old. Mine was the third cleaning. Customer vacs every two days. The volume of scum is less with each vacing. Spotters have been used in a couple small areas. No powder.
    The loom oil theory might fit. The first two cleaning were probably quick rinses. Then I spray Flex with Citrus Solv, which emulsifies or partially emulsifies the oil. But wouldn't Ice rinse the emulsified oil?
    Customers are good people. She's a retired cop, and a friend of another retired cop friend. He's a retired fire captain. They have funner things to do with their time than harrass the carpet cleaner.
    Matt Wood likes this.
  18. ruff
    9,205
    San Francisco, CA
    Name:
    You sure about that :winky: ?
    Lets vote.
    How many here vote that client has funner things to do than "harass" Johnny?
    Steve Lawrence and Old Coastie like this.
  19. hogjowl
    Feb 19, 2007
    27,033
    Prattville, Alabama
    Name:
    Marty Sutley
    Sounds funner to me to mess with Johnny
    Lee Stockwell and Mikey P like this.
  20. Old Coastie
    4,908
    Heart of Dixie
    Name:
    Ain't you choked on a chocolate raisen YET?
    hogjowl likes this.
Share This Page
