Fresh water pressure tank refill
WillH
Albany,Ny
Capital region carpet cleaning
i was wondering if or how often do you have to refill the pressure in the pressure tank . The reason is I think my tank lost its pressure because it won't push water to the fill box. The pump seem to be working. The line are not clogged. Any suggestions thanks
Benton KY USA
What model of machine? Do you mean the accumulator bladder tank that works with the electric pump that fills your water box?
The problem you described is not often related to it.
Benton KY USA
Even if you consider yourself "not mechanically inclined" ( I never believe that term) you can with logic and process of elimination figure out most problems.
1st step, ask for help. You did that.
Now, let's find out if the transfer pump is pumping water. If you can't otherwise observe it, take off one end of the output hose.
There can be a number of simple answers, depending on this observation.
I'll wait....
Reactions: Bruce Humphrey
WillH
Albany,Ny
I took off the bladder the other day and was the pump was pumping water.
Benton KY USA
The bladder is a sort of "shock absorber" for the pump, to keep it from cycling on and off so much, and evens out the flow.
Benton KY USA
Ok pump runs, you see output, it just needs enough to fill the water box.
Debris in the valve body of the pump, or clogged inlet filter could reduce flow or pressure. Likewise a kinked hose.
WillH
Albany,Ny
I planed on taken the pump apart tomorrow to see if it's clogged and check the valve thanks for the help I'll let you know what I find
