Help making a sling ring for cimex or 175 buffer.... OR where to buy one
JoeClean
for Tile scrubbing
Can someone link to where to buy best material to make one of these?
read about using garden edging but what kind.
Also how to secure to machine so it looks professional, etc.
thanks!
Erik
Michigan
Erik
McMaster-Carr
UHMW
Part# 8702K28 or 8702K68
Either one is flexible enough to bend to the radius your looking for.
dgardner
Phoenix, AZ
Dan Gardner
Don't secure it to the machine..just let it ride along loose.
Like this? (at about :35)
[video=youtube;mqpnWVdyPkc]http://www.youtube.com/watch?v=mqpnWVdyPkc&feature=player_embedded#t=36[/video]
:biggrin:
JoeClean
Thanks for link. If you are letting it ride along loose, how much bigger than the machine do you make your loop.
Looks easy to make.
davendana
hoth
d Jackass
Maybe two inches or so bigger than the 20 " and the rear wheels
Sent from my QMV7A using Tapatalk
GCCLee
East TN
C. Lee
I cant read that!
Do you see anyone else posting in another language here?
Southern California
cameron demille
For me personally, the garden edging is terrible. It's hard plastic and doesn't do the job. A nice dense rubber is heavy enough to constantly fall to the floor and almost create a seal. I had my Cimex splash guard modified, but then it disappeared. I used some stuff from ACE last time, I think it is clear plastic/rubber draw liner. I cut it into the size strips I needed then doubled them up to make it extra thickness. I used vinyl stucco tape to tape everything together and added layers of tape on the bottom to create a soft contact point. Not as good, but it works a lot better than plastic garden liner.
GCCLee
East TN
C. Lee
Perfect COlor Choice Doc : )
Srry fur the hijak
My .02, getcha piece of platic gutter, heat it an slowly bend it around a 19-20" form of sorts (A 35gal drum might be perfect) PVC pipe for your vac attach
make a T and get it all together, glue it screw it what ever from here, make it pretty. An don forget to drill holes in da bottom : )
N GA
BradFenstermaker
I second the rubber baseboard. You can buy 3or4 ft strips at Lowes.
It took me 2 piece for my 20 in. I wrapped it around with slanted edge facing away from machine. Just like win its installed to wall.
Connected the pieces with zip ties after cutting X slits. Took utility knife and trimmed for detailed fit under the wheels.
Nice functional fully enclosed splash guard for under $10.
