No vacuum pass needed?
You could see the water shooting out the sides. That entire floor should have been dry passed. But it was hard to tell exactly since the video quality was on par with a big foot sighting.The guy that posted this video mentioned he used very strong mix pre-spray...so the Bonzer is essentially rinsing. There were streaks in the original video that the guy said came out with his dry stroke. Edited video.
Hopefully you didn't raft him,
It would be a lot more entertaining if we had legitimate videos from real Bonzer owners that weren't posted by Rotovac. Pretty sad when the manufacturer has to toot their horn because nobody else will.
Lee Stockwell Leaving streaks in the video
Ryan Jankauskas I addressed that to a few other people. Doesn't leave them when I dry pass. With 500psi it doesn't leave them at all.
Roger Loghry Loghry so does the wand the sx15 360 the bonzer has made ny life alot better when i clean residential carpet with it looks beatifull so dont knocvk iot till you try it!
Jc Ladyfish It does appear that the zipper doesn't leave those streaks and may not require a dry pass, judging by some vids that I've seen.
Sam Miller That's what I keep seeing too. Maybe psi to high?
Ryan Jankauskas At 500 psi it didn't leave them. I had to use 700 on this horrendous area. It was well worth the dry pass to get those results and blow them away. My rx-20 didn't leave it this clean. Doing the dry pass was still faster then using my wand doing over it 3-4 times back and forth.
Maybe I am but it seems every time I see something positive about the Bonzer, it's coming from Rotovac. Do you own a Bonzer? Have any videos you can share?You're really reaching here............
