Auction New Rotovac 360XL SUPER AUCTION
MB Auctions
Up for grabs is a shiny new RV360XL.
$1.00 minimum bid increments but bid as much as you like.
$2800-$2900 value w/ shipping!
Here is a great chance to save loads on what is arguably the deepest cleaning Rotary Extractor available. Definitely the smoothest and quietest of the bunch!
Side by side testing done under the watchful eye of Industry Tester Extraordinaire Larry Cobb proved that the XL put out one half times as much water as the competition
Unit will be delivered free of charge to the winning bidder assuming they live in the lower 48, otherwise they pay the going rate.
Clear site tube included.
Rotovac 360XLProduct Details
The Rotovac 360XLis a Patent Pending Rotary Extraction Power Head that utilizes rotary vacuum heads to thoroughly deep clean carpet with hundreds of multi-directional cleaning passes. The 360XLweighs only 68 lbs and is extremely easy to use as it operates in a self propelled side to side motion. Simply stated, “The 360XLcleans better with less effort.'
Works with most Portable Extractors or Truck Mounts
  • Features:
  • Cleans better with less effort and leaves carpet drier than a wand
  • Large 15' wide cleaning head
  • High torque motor with tough helical reduction gearing
  • Patented Swoop Glide™ vacuum ports
  • Telescoping handle for compact storage
  • 144 RPM
  • 55 lbs (without cleaning head) 68 with head
  • Rugged cast aluminum frame
  • 2' clear view tube
  • Unique marketing tool, land new accounts and generate referral business
The Rotovac 360XLis air flow calibrated to work with most portable extractors or anytruck mountextractor. Give your business a boost and your back a break by hooking up the 360XLto your existing portable or truck mount.
New Rotovac 360XL
It says current bid 1,2 , that's how it looks on iPhone and iPad is that $1200.00? At a dollar a bid that's a lot of clicks
Zee
SoCal jungle
I bid....just to piss off those that think it will go for 58bucks
And it would wouldn't hurt to win anyways..
Does this one have crack able gears if you hit a door jam?
