Village Idiot
- Joined
- Jul 13, 2011
- Messages
- 26,363
...a sill plate is the bottom of a widow ( term. window sill)...
https://en.wikipedia.org/wiki/Sill_plate
Screw all of that. Find a way to dry it.
http://www.floridabuilding.org/fbc/thecode/2013_Code_Development/HVHZ/FBCB/Chapter_23_2010.htm2318.1.4 Sills and/or base plates.
2318.1.4.1 Sills and/or base plates, where provided in contact with masonry or concrete, shall be of an approved durable species or be treated with an approved preservative and shall be attached to the masonry or concrete with 1/2 inch (13 mm) diameter bolts with oversized washer spaced not over 2 feet (610 mm) apart and embedded not less than 7 inches (178 mm) into a grout filled cell of masonry or into concrete. Base plates shall be placed in a recess 3/4 inch (19 mm) deep and the width of the base plate at the edge of a concrete slab, beam/slab or any other type of construction which uses a masonry surface or concrete slab, or be provided with an alternate waterstop method as approved by the building official. Alternate methods of anchorage may be designed by rational analysis by a registered professional engineer or a registered architect proficient in structural design.
can you point me to the window in your illustration?
I would safely say you could call it the "board that was once wet".No idea what the f-ing board is called but that shit is almost dry!
