Sonrise1
I need you all to help me understand "flow" as it relates to carpet wands. I understand that higher flow results in more water, but how much. When you say "my wand is 9 flow" what do you mean?
I like you![]()
High Flow wands, more water or just faster?
Seeing how the 12, 16 and 24 flow fad is over, what have you old timers who were here for the Greenie Revolution, settled on flow wise? Sure 12 and above let you move the wand faster and flush deeper without as much need of agitation, but at what price? Less heat unless you bought a...mikeysboard.com
Correct me if I am wrong but the numerical value of what flow you are running is based off how many gallons per minute will flow out of a given orifice at (I think this is right) 4000psi.
Can you tell use what machine you’re using on that wand?I need you all to help me understand "flow" as it relates to carpet wands. I understand that higher flow results in more water, but how much. When you say "my wand is 9 flow" what do you mean?
I like being a meatheadDon’t listen to those meatheads above. Just follow the chart to the specs on your water pump on how much gpm it can put out
We refer to flow as it relates to the size of jets you have on the wand. 3-11003 jets will give you a 9 flow. 2-11003 jets will give you a 6 flow and so on. Has nothing to do with GPM, it's just the size of the jet or jets.I need you all to help me understand "flow" as it relates to carpet wands. I understand that higher flow results in more water, but how much. When you say "my wand is 9 flow" what do you mean?
I guess in the sense that we refer to it......meaning not usually having any idea how much....or at any standard pressureWe refer to flow as it relates to the size of jets you have on the wand. 3-11003 jets will give you a 9 flow. 2-11003 jets will give you a 6 flow and so on. Has nothing to do with GPM, it's just the size of the jet or jets.
Guess my welding cleaner tips are wrong. I use the .015 for just that.
Coming from the machining industry I agree with Ron.
A 11003 is a .030 opening. The 110 is the angle. You can't get a .030 tip cleaner in .015 opening. Different pumps will produce different flow rates at equal psi. At least in my experience.
Think of using an electric sprayer compared to your truckmount. The smaller the pump the less water you get through the same orifice.
It's about the back pressure.
Yeah yeah yeah. I really thought that's what it was. Guess Fred taught me better. I will measure it some day if I think about it when I have my tools out.
Nothing wrong with running your wands at 500 psi.Just got a new Aerotech. It flows 6gpm up to 1600 psi. We run our wands at 300, zipper at 500.
