Russ T.
What the hack is a #3 blower EZ?
I should have included Cleanco, regrettably..
That sounds pretty awesome.i think I remember Justin mention it last year at MF10.I don't really believe there's that much of a difference between all the direct drive units as far as heat. I think the newer GM vans run hotter than the older GM engines. My 08 runs at 215. The 99 at 195.
The Cleanco offers a really cool option that preheats the freshwater while you drive. They are the only DD ones that do that.
The higher engine operating temps are (IMHO) why the direct drives are able to handle more flow at high temp.
But why not start off with a tank of 175 degree freshwater? A cat pump with high temp seals won't have a problem. Aero tech does it.
I actually didn't see it on Cleancos site.I had no idea that was an option. I see that I need to talk with Mike at TCS in a little more depth about this.
Even leasing it for almost seven years and with a pretty high residual the aerotech is still way more than a Butler. Honestly the finance options on an Aerotech aren't nearly as good as Butler. A Butler depending on options is about 1100 for 5 years. Even at 3% interest you couldn't hardly keep an Aerotech under 2000 a month. I'm not saying they aren't worth it. But 2000 a month could get away from you if your not careful.
