Zipper Improvement
Erik
Michigan
Erik
Thanks Gene! Let me see what I can do.. If your talking about cleaning back to a transition area, I turn around to clean them.
Erik
Michigan
Erik
"Ok so make a holder for the fels. It can pop right into the spot where the two bolts hold the hose."
That really is a good Idea. It could snap into the plugged holes on the front of the handle. The Injection mold will be expensive, maybe you can make a wood prototype and screw it into the plugs.;) Wood model making is a lost art..
jwfoulk12
PA
Justin Foulk
Hey Eric something I was thinking the other day as I was using my zipper in a smaller bedroom. Is there any way to put a swivel on the head of a 13 inch model? Is there a swivel that you could lock in place when you wanted but could also be freed to swivel when you wanted as well? That would be prety bad ass.
GeneMiller
Boca Raton
gene miller
It also needs to double as a small bottle and tamping brush holder.
this is what i was thinking . folded stainless, you could push two tabs out the back and it could just slide into the two bolt holes. i wasn't thinking two fancy. you could add a loop on the outside for a brush. i may try my hand at bending. probably since my hand up. lol
Reactions: Erik
