[FONT=Verdana, Arial, Helvetica, sans-serif]Why Do Most Steam
Cleaners Offer "Free
Deodorizers"?[/FONT] | [FONT=Verdana, Arial, Helvetica, sans-serif]This is to mask the odors of the wet carpet cleaning. Sometimes referred to as the wet dog smell. The best smell is no smell. A properly cleaned carpet should have no artificial odors after cleaning. You should notice only a freshness in the air.[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Steam Cleaning
Sanitizes?
[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
[/FONT] | [FONT=Verdana, Arial, Helvetica, sans-serif]Not Possible! In order for heat sanitizing to take place. The following is required. Minimum of 165 F temperature must be maintained for minimum of 15 minutes.
Consequently the hot water used for steam cleaning
can only stimulate the growth of bacteria, mold,
mildew and odor. [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]What is Steam Cleaning?
(Hot Water Extraction) [/FONT] | [FONT=Verdana, Arial, Helvetica, sans-serif]The word Steam Cleaning is misleading, only hot water is used. There is no steam and if the temperature of steam was transferred to your carpet, it would be devastating to your carpet such as the destruction of dyes, fibers and glues.[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]How Does Steam Cleaning Work?
[/FONT] | [FONT=Verdana, Arial, Helvetica, sans-serif]Steam Cleaning relies on large volumes of heated water and vacuum to flush soils from carpet. In order to deep steam clean a carpet to the base, it must also be soaked to the base in order to attain this deep clean flushing action. Deep Steam cleaning can cause many problems with your carpet. [/FONT]
| [FONT=Verdana, Arial, Helvetica, sans-serif]Fast Dry Steam Cleaning? [/FONT] | [FONT=Verdana, Arial, Helvetica, sans-serif]Claims made by the Steam Cleaning Industry is that a Super Powerful Truck Mount Vacuum will dry carpet super fast. This fast dry Steam Cleaning can only be achieved through a fast skimming of the carpet surface so that the water dose not penetrate and clean deep into the carpet. Vacuum suction can only remove loose available water from Your carpet.[/FONT]
| [FONT=Verdana, Arial, Helvetica, sans-serif]You Cannot Judge a Steam Cleaned Carpet while it is wet [/FONT] | [FONT=Verdana, Arial, Helvetica, sans-serif]All wet carpet looks great. The same way the paint color on your car looks great when it is wet. As the drying process begins you will notice an overall dulling and dead look to your carpet when compared to its wet state. Wicking back of soils that has been
flushed into your carpet are very common with Steam Cleaning. [/FONT]
[/FONT] |
| [FONT=Verdana, Arial, Helvetica, sans-serif]Is Steam Cleaning Green?[/FONT] | [FONT=Verdana, Arial, Helvetica, sans-serif]Environmentally friendly green cleaning goes far beyond a particular product used to clean carpet. Green cleaning is all about the carbon foot print and the effects it leaves behind in the environment. Truck Mount steam cleaners have the larges negative carbon foot print in the carpet cleaning industry. The manufacturing , operation and maintenance of a high powered gasoline engine, vacuum pump, water heater system, rubber hoses, tanks etc. and a heavy weight cargo van for transport all leaves a huge carbon foot print behind. Large volumes of fresh water are also consumed.
"Man will always justify an easier and faster way to get the job done, regardless of the results or consequences."[/FONT] |
