2012 fuel tap.
Becker
Snohomish, WA
Becker
Picked up a 2012 e350 with 15k miles.
I need a proper fuel tap with return.
Dot approved.
Who has one. How much.
I installed the one on my 06 pita but was not bad.
Becker
Snohomish, WA
Becker
Not in a huge hurry as I want to have it lettered and rigged before tm goes in.
Thermalwave goes in the 2012
Prochem 405 will go in my current van.
John Olson
Orem UT
John Olson
So Larry are you actually making these? Your website claims you are. Only DOT certified fuel kits I know of are transfer flow. Pleae post a copy of your certification
PA
I'm Rick James
Where did you go and what price did you get it for? I am looking for a new ford with windows, 2008 or newer. The local Jon Don doesn't have the tap?
Becker
Snohomish, WA
Becker
Brent, you'll have a hard time finding a new 2008.
I got a 2012 one ton with 15k miles under $18,500.
Pull up auto trader. You have no problem finding a used 2008 or newer.
I'll inquire at Jon-don, in fact headed there today for some supplies., but I'll gladly order it if the savings is huge.
In 07 I thought I paid nearly $500 for it. Seemed absurd.
PA
I'm Rick James
Well more like gently used.. nothing with over 70,000 miles.. There was some good deals but they go quick.
I paid around $600 with install for the fuel tap on my chevy.. the good thing is with the new ford i'm getting is I won't need a fuel tap, the machine is going to run off propane.
Becker
Snohomish, WA
Becker
Setting up properly for propane will make a fuel seem cheap.
Just left Jondon.
Lol.
Joe is gone. At check out I requested price.
Answer I got was. I'd not even know a part number and rather than helping me he suggested u ask someone else.
That's screwed up. I was the only customer in the store.
Guess I won't be buying it from Jondon.
John Olson
Orem UT
John Olson
Transfer Flow DOT Certified Fuel tap with return is $216 wont have them until the 21st though
Dallas, Texas USA
As usual, John is mouthing off without any shred of actual knowledge.
Transfer Flow makes the only non-OEM EPA-approved fuel taps in the U.S.
That is the manufacturer of the one I referenced.
Even their taps, need some special mounting considerations,
for best performance.
Larry
John Olson
Orem UT
John Olson
Edited because you edited your website and added transfew flow as the manf in the descrption when it only said dynachem as the manf. Before..sneaky :) good one though
Cleaning Equipment Parts
Product 273/1356
larger image
DC601 - Fuel Tap Kit 2011-2013 Ford Cargo Van EPA
$229.95
Fuel Tap Kit - Fits 2011, 2012 & 2013 Ford Cargo Vans
Includes Low-Emission Rubber Hose
Meets EPA regulations for limiting emissions
Manufactured by TransferFlow
Add to Cart:
Model: DC601
Manufactured by: Dynachem
You should edit your post John.
What's up with you lately?
Either you got a new device or are hittin the sauce too hard, cause your typing sucks.
John Olson
Orem UT
John Olson
It was early and my fat fingers and the ipone don't go together...well they don't go to well with my computer keyboard either...
John Olson
Orem UT
John Olson
TW takes about 45 minutes the guys take a little longer as they get checked by TW and they know the fuel kits is not something that "just ok" is acceptable it has to be TW acceptable. Also an older Chevy is easier then a newer one and a ford and dodge or different. We charge an hour regardless though and if the guys take 1.5 then it takes 1.5 they are the ones that sign their name to it and quite frankly the life of the operator and everyone on the road or in the houses they clean are on their hands.
Scott Rogers
The transfer flow kit was way simple to install. took me 20 minutes this past weekend. Never did it before and was nervous as hell. Couldnt beleive how easy it was.
Scott Rogers
O.yeah, 1 unexpected benifit of the new tap. I was able to eliminate the electric fuel pump that my old van required. My kohler wouldnt run without the electric fuel pump I guess because of the smaller hose on the old tap. but no issues drawing straight from the tank with the new tap.
Dallas, Texas USA
Scott;
Operating without an electric pump, will work on some engines.
The real test is hot weather in the summer causing vapor lock.
We usually bypass the engine pump, and install electric pump at the tank.
Larry
