Cobbs Powermax Problem
R
Ralph Pastorelli
Where is Marty with a ball busting response to this topic? He always has something mean to say!:stir:
joey895
Joey J.
until you get used to mixing in the hf container, mix it in a bucket with hot water and a paint stir stick. put funnel in hf container pour should work fine. I use 1 cup(8ozs/4 scoops) to 1 gallon hot water in a normal hydroforce.
This is what I do.
This stuff is not rocket science. I use to be lazy and just dump the powder straight into the inline and shake but in the end that just makes more work.
Also when mixing in a separate container you'll be able to see if it didn't all dissolve because there will be some powder at the bottom of the bucket.
Sent from my Galaxy Nexus using Tapatalk 2
I use one of my 2 gal multisprayer jugs to mix my powders then I pour in the hydro as needed.
Don't use cobbs though.
That way I can pour in my 40 vol or a deo as needed too.
Waldo had called or text me 6 times to tell me what an idiot he has been for NOT using a HF all along.
listening to Multi Sprayer fags like Larry turned out be a huge time waster.
Reactions: joey895
floorguy
Doug
unless you are on a big job and dont want to keep unhooking the wand....
which is why i have my old porty as a sprayer....and a 50' hose...i dunno how people use those little 5 gallon sprayers:very_drunk:
Waldo;
We mailed you a filter and hose barb for your inline sprayer today.
The small nylon filters don't have enough filter area.
Larry
The ONLY way they make $ense (when they draw right) is for one man crew .
otherwise, you're an idiot to stop the wand to pre-spray
Reactions: hogjowl
Get a splitter at the door and t off to run a solution line to the Hydroforce. I'd spend a little more and buy powered that dissolves easier.
Time is money and if you taking the time to try to get it to hold in solution or cleaning out the filters, you're not saving what you think you're saving. Labor is your bigger expense, not chemicals costs.
You might think that, but in practice it goes very smoothly.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
We REALLY need an "you're an idiot" button on this board.
Why can't we have one Fred?
PS I have grown tired of explaining the correct job management procedure to you people. So, that is why I have not contributed in this thread.
Reactions: Ralph Pastorelli
R
Ralph Pastorelli
I'll stand in for him this time
good to see you back PasDUHrelish .
we haven't a dumb dago here since that jabroni Segretti got bounced :icon_razz:
Nice response how you been? I'm not around much in the busy months or at Fenway Park on weekends GO REDSOX!
R
Ralph Pastorelli
We only use ServiceMaster products that work very well so no give 2 craps on how the junk out there works:razz:
R
Ralph Pastorelli
Actually our fire cleaning products are made by Un Smoke with a different scent and I no clue on carpet chemicals.
Louis is correct.
PowerMax has a time-release oxidizer.
By design, it does not dissolve immediately, unless the water is very hot.
Some inline sprayers have a very poor small filter for the chemical feed.
This is the "acorn type" you need to prevent clogging:
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=68&products_id=5173
We will provide one at no charge to anyone who has ordered PowerMax,
if you ask.
Larry
Thats the screen I have on my Hydro force and the only thing that plugs mine is teflon advanced if I don't strain it out first cottony crap everywhere.
Never had a problem with any powders but I do mix every thing really hot and shake.
1
1moondog1
HMMMMMM! Been using for 5-6 yrs now and do have to perodically shake as we spray in both hydoforce and spraymeaters never had a problem though?
Product has been INCONSISTENT in the past but the 1000 lbs have been good.
I'm doing al'ite in spite of myself
to get you caught up,
WalDoh is still a dOpe
Marty is still a prick
and Jimmy is still Jimmy..
R
Ralph Pastorelli
I see that Marty is still a pig farmer, waldo is still clueless and Ladwig yeah is Ladwig.
1
1moondog1
Because it comtains sodium perc or like product and is best used FRESH.
