Hard part is over. Machine is in.
Becker
Snohomish, WA
Becker
It's in. Needs to be squared up. But hard part done.
From garage floor to the van.
Getting close.
Reactions: Art Kelley
NY
Ralph Pastorelli
We wash the dirty tanks once a week and no stench but the Prochem slide in does give off a fuel smell if my guy's don't idle it down right and shut it off right away.
Doug Cox
Delavan, WI
Doug Cox
You get the worst stink when you suck up animal piss. I empty my tank every night and have been putting bleach tabs in on a regular basis.
Arizona
Tank is drained nightly. And rinsed often. Cooler climate most of the year no real problem.
I don't get any smell out of mine even in our heat...roof vet and drain it out every evening....
PA
I'm Rick James
If you put furniture sliders under the machine you can move it so much easier and not tear the carpet. I am about to install a HM in a new van, but I am running it out the back door with the exhaust vented under the van.
Becker
Snohomish, WA
Becker
I'm sure sliders would make it easier. I used them on the waste tank.
Under the machine I used 1/2 black pipe.
Worked well.
