Official David Gargan Pro 1200 Install Thread
sweet....put this up top as a sticky so we can keep track of it........
Extended Fords have the same wheelbase as standard, and stick out 20" more behind the axle.
Extended Chevy/GMC have 20" longer wheelbase and don't have extra behind the axle. Ride smoother, don't turn as tight.
Reactions: GCCLee
B
Becker
Where are ya towing it? And why did you suck that nice liner off.
John Olson
John Olson
That was it showing up. The picture didn't post in order. Been fighting posting the pictures. We start the actual install monday
G
GCCLee
98% of the time, we run out the back doors.
So I put an access port in the floor for the lines so I can shut the doors! It's cold out.
Did you all spray it or just contract it?
That's exactly how ours was sprayed : )
Oh good. Thanks John.
I'm getting one. So it would be interesting to see.
is that a solution draw line curled up there..looks lik a foot valve on the end
Art Kelley
If you stand on your head you can see it's just a simple strainer.
ok THAT made me dizzy.......................er!
so is it a draw?
i gotta know for when i build one.......
only MINE will be brand new!
Art Kelley
I used to have one of those chemical draw lines dutifully drawing nothing but fresh water from the 5 gallon chemical makeup jug. (I never run that emulsifier crap). Eventually, after 5000 hours, the drum on the diaphragm pump hooked to the Cat pump broke. I took it off and repaired it but never put it back on. It really was pointless for me to always be filling and drawing nothing but fresh water all the time. Plus those five gallon tanks take up a lot of space.
KevinL
Kevin Leach
Why bother taping off the sides. What does it matter if some over spray gets up on the wall. I'd rather have it there than thrown away with the paper.
B
Becker
Not a huge amount of over spray. Some like a sharp edge. A tapered orange peel might look kinda cool.
So how did you test the rinse I sent you?
Art Kelley
You mean the prespray/rinse MikeyJuice? Good stuff. I used it as a prespray on rugs and wool carpeting. It rinsed out great with hot water. I did use it for superfast one step upholstery cleaning misting it with a trigger sprayer and vacuuming with a plactic cuff with my other hand. I hope that stuff is put into production.
You can order it now Art.
Magic Potion Neutral is what to ask for.
We'll have a direct link here soon
Reactions: Art Kelley
Wow there is going to be tons of room in there to put stuff. Congrats david
