- Oct 9, 2006
- 64,833
- Name
- Rico Suave
Yea I like the space savings!
I meant an answer from somebody who really knows.
I ruled you out before I even started typing.............
By the way...this is a great looking unit........FOUR STARS......
it would be FIVE if it had a larger waste tank!
thanks John
are those stainless tanks...if they are
you gots a winner.....
i wouldn't want all that money to be sitting on aluminum
No, I don't know and an lotJohn,
I Luv U Man : )
Can the 1200 by itself be purchased ?
Super Serious, Can the Front and Rear DS mounts be purchases separately : )
Most important, How Many Jelly Beans do you get with a TM purchase/install?
No finger pointing fellas!
Ill post the picture (thought I did) of the pulleys. This out first so don't know if anything is different but I'm pretty sure the drive shaft goes where to goes on all the configurationsJohn, when the waste tank is under the machine do they add an extra pulley to keep the drive shaft coming in lower or is the drive shaft raised up to come into the same pulley as usual?
John Olson" data-source="post: 4257513" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Don't think they will work for you but I will see what I can do.
