Official David Gargan Pro 1200 Install Thread
YOU might do it that way, but a chimp is going to pull the hose out and away he goes. Those hoses are GOING to eventually rub the rubber off that door edge. It's a given.
Yea, maybe but won't they be better served if they just peel off a 50 or 100 and walk an arm full in?
I think it they try the walk and drag a couple of times they'll find it to be not only slower but harder too. :icon_neutral:
This bulletin board world you've been living in for the past decade has finally left you completely devoid of practical intelligence.
I've got to honest with you Pigshett..... I began with very little! :rockon:
I blame solvents, they damaged my brain cells. :p
That sub-mount tank needs to be closer to the machine. As it is, the hoses are going to be coming across that door jamb when coming off the left side of the hose reels.
That is why I want to BE THERE when somebody is installing my stuff.
I could just imagine the man hours spent waking your ass up in the cab of the van every time they needed to do something.....
Reactions: hogjowl
Art Kelley
It would be one of the greatest pleasures of the equipment installer's life to have Marty looking over his shoulder while he worked.
I could say something negative here but I respect you far too much....and the light is about to change
John Olson
John Olson
you not only have to be able to install it you have to be able to work on the machine. As I is this is what happens when trying to tighten the bolts.
P.S. Yes he FELL in and yes it was a bitch getting him out.
Russ T.
Russ Terhaar
Man it looks like those water ponds save a TON of space. I think I saw a pic of a Cleanco with their version of water pond mounted flush against the machine. It left the whole back wide open to do whatever you need to. This SS looks sweet too! Is the SS designed differently, causing you to leave a space between the two for maintenance?
The Clean Machine
Reactions: hogjowl
John Olson
John Olson
You have to be able to bolt it down and reasonably reach parts on that side and it has to be safe. The last thing that will ever kill you in an accident will be a machine and or tank etc that we installed. They ain't coming loose. TW put it where it made sense with the least amount on inconvenience for everyone.
Hoody
Steven Hoodlebrink
Years of Experience
20
All I know is if I was still in the biz and bought brand new it would be from John and they would install it. Im not saying that because he is my friend, I am saying that because I have watched TW and Bud install machines many times. I have also seen them find crap installs and fix them because they refuse to let someone drive around with it being unsafe. They also have some neat fabrication abilities for custom installs too.
TomKing
Tom
Role
Years of Experience
20
I hope you are dropping a water pond in it. Oh there it is my mistake very nice. My friend.
Wow there is going to be tons of room in there to put stuff. Congrats david
TomKing
Tom
Role
Years of Experience
20
If that one of those live vac reels?
GCCLee
C. Lee
Id like to see this thing Knox.
Jus not in my town : )
nice machine with a nice looking install.....
thanks for the pics John
