encapman
- Oct 7, 2006
- 2,371
- Name
- Rick Gelinas
Wow! I've never had that with Snake oil, just Releasit and only when it's sprayed. That's odd.
Hey Richard, that's the reason we reformulated Encap-Clean DS (coughing was sometimes a problem with the older formula when it was sprayed). Encap-Clean DS2 has been reformulated with a new surfactant that doesn't cause coughing (hence the "2" designation). It never was the Tea Tree that caused coughing, it was the surfactant. So we had to find a surfactant that wouldn't cause coughing when it was atomized into spray droplets. Yet it also had to clean well and work in conjunction with encapsulation technology too. After a lot of looking we found a way to tweak the formula and we solved the coughing issue - plus it even cleans a little better. Encap-Clean DS2 is not causing coughing. I can send you a sample if you'd like to check it out.
