I'll admit it, the Clear SS is way cool..
Arizona
The Strykout wand has been discontinued.
As for the uph tool, just a clear top plate would be lame IMO.
I tested that wand for quite awhile.........different Teflon set ups......etc..
got the thing down to a perfect set up and with the conventional handle instead of that big blue one and it was a perfect wand....
good flow...good flush..holds heat....
I did not want to give that one back....
IMO..if they make it and stick to that set up...it will be another hit........
John Olson
Orem UT
John Olson
Mikey there is a precedent for making a clear top cover. It will allow people that already own the tool to gain the advantage of seeing the water/dirt being extracted without having to buy a whole new tool. Also if they are able to make it at a price point that isn't cost prohibited to replace every so often when it clouds up, which it is going to then it will be worth it. saying it would be lame before it even hits my door sounds like something Marty would say. Hell it might no even happen if the cost cant be controlled were it makes smart financial sense for everyone which includes the cleaner
dgardner
Phoenix, AZ
Dan Gardner
Would the clear bottom be the same mold as the colored one? Then make the top piece available as a replacement. You could buy the whole clear tool, or buy just the top to replace the top of the old tool.
Sent from my ADR6300 using Tapatalk 2
Charlie Lyman
Meridian, ID
Charlie Lyman
How come we don't see cool tools like this introduced on TMF?
Sent from my motorola flip phone using Crapatalk 1.1
lol!
Because Rob is the Martha Stewart of the Bulletin Boards?
Watch his videos, have you ever seen him clean a house that was not staged? Ever seen an employee that was not some cute homeless chick? No company worth anything cares about his opinion.
Reactions: Shorty
Charlie Lyman
Meridian, ID
Charlie Lyman
lol!
Whats his videos, have you ever seen him clean a house that was not staged? Ever seen an employee that was not some cute homeless chick? No company worth anything cares about his opinion.
If it wasn't for his videos, I wouldn't know how to clean stairs.
Dallas, Texas USA
I have a question about the SS Tool ?
Did they make any changes to the new mold ?
I do like the tool, but several buyers have complained about a small void in the vacuum extraction,
in the very center of the tool.
Has anybody noticed that who cleans daily with the tool ?
Larry
Larry
only a non dry stroker would notice.
Never seen or thought about it and yes, daily user here. Own 3 of them now.
Larry
We have (4) of the Sapphire blue tools and someone cleans with one nearly every day between the shop and the field. Never seen or heard what you're describing. Any pictures Larry? Is it possible there is a ball of lint restricting the airflow? Have ever cleaned it out?
Dallas, Texas USA
My upholstery specialist returned his brand new tool, after several repeated calls to Sapphire.
Certain fabrics show it more.
It is just a little tab in the center that can be manufactured thinner.
It should have been more visible on the clear tool,
if they are the same casting.
Larry
GCCLee
East TN
C. Lee
u sure bout that one mickey?
Thought I heard the schnauzer say it was different. Do ya have a Blue one ta play wit pappa : )
Noble Carpet Cleaners
I asked my local store to look into if this new clear top half is available and haven't heard back. If I find out it's "extra" and exclusive I won't be surprised.
same cast but the die change will cause enough variance that the screws may not align is what Kieth was told.
Scott If the clear option comes to be, John Olsen will have exclusivity for a while.
Dont even bother other distributors at this point.
Reactions: GCCLee
J
JS41035
Can you swap then out real fast to see if the clear head will work on the blue tool? It would answer that question in ten minutes.
J
JS41035
Larry
No never. I have cleaned hundreds of theatre seats and dozens of couches. My only complaint is the valve can twist open while your dragging it between seats. Other than that it's pretty smooth.
Reactions: dealtimeman
Erik
Michigan
Erik
I like it. They have the molds. The clear top would cost as much to ship as it would sell for or not. Considering what the tool cost, its probably a $125 part. I'll take two:icon_twisted:
Ray Burnfield
Redwood City, CA
Ray Burnfield
Clear plastic doesn't look very good after a short time in the field. The clear part could be replaced at a cost.
Should Sapphire make a blue tool and a clear tool?
I think they sell a few blue ones now.
How about a completely clear Studebaker wand?
