K
kingjoelking
It sounds interesting. Excuse me for being skeptical as I have never seen a 1 filter RO system.
Sent from my SCH-I605 using Tapatalk
Benefits of RO/DI:
Zero scale build up
Dramatically reduced chemical usage
Their is also a very odd effect when the carpet dries it has a brightening effect
Fibers are left far softer than you could imagine
It just cleans better!!
Water heats better too
Demien
Richard;
Our Dynachem RO System will add ~ $1000 to the TM pricing.
It has a 48" long RO membrane rated for 2300 Gallons per day usage.
This means it will last thru about 10,000 gallons of moderately hard water.
So a 34HP TM with RO system would be $16,195.
Along with Dave Gill,
I firmly believe in the superiority of RO water for leaving the least residue in the carpet.
Larry
And what is the cost to install your system on my existing truck (I have a general pump and fresh water tank)???
$2000, if you do the install
Will you guarantee the output TDS of your RO?
No, but we see 25 TDS on existing systems
Do you have a DI option??
No, we offer RO system only
How fine is your sediment prefilter???
5 Micron
What is the maintenance like on you system?
Replace Prefilter every 3 months, Flush RO filter 6 months
is the general pump pumping city or RO water?
Both
Demien
i like the demand pump and all but for that money it makes larrys system look like a deal. plastic housing vs stainless housing?
larrys cost 2000 the one in the link 2200 for plastic?
i do believe larry pre filter is plastic but the main housing is ss. i also like the amount of surface area of the one in the link as it looks like a very large surface areas for the carbon filter.
do you think that ss is of some value vs the plastic?
i am not challenging you, i am asking you as you have experience in using this system? any pros vs cons to the plastic vs the ss?
So, will filling my tanks with soft water prolong the filters(all of them) life? I'm thinking that I would still like to have water tanks and not hook up on any jobs..
No. besides the idea of my system is not to direct feed your TM, rather use your FW tank as a "buffer" tank.
Personally I use a 35 gallon Buffer tank, and it keeps up. I run a 12 TI.
Your filters?
As in that is your website? And your design?
Maybe this has been discussed and I missed it.
How much water is wasted or used? Is there a ratio?
