"area" and "room" pricers and stairs
Loren Egland
Loren Egland
I am not a room or area price cleaner. Most cleaners charged by the square foot when I started steam cleaning in 1970. If the stair is three feet wide, our charge is $4.00 per step. So 12 to 16 steps range from $48 to $64.
I think it is time for a new stair tool.
Is that 30 inches??
I went out to the shop and measured it and am sending some pics too...
Standing leaned up against the tool kit and at the angle you would be able to clean at, it is about 23 inches from the floor.
Laying on the floor, it is about 34 inches long. It is a 1.5 inch diameter tube. We just throw a whip on it. The only hose we reduce down. Tried reducers on the end of the 2 inch, but just like the whip better. Doesn't work us and beat us up....
My Son in Law is about 6 foot 5 inches and finds this wand comfortable and fast for him. I am about 6 foot and feel comfortable with it as well. Here is that video link again of Him cleaning with it.[/B]
https://www.facebook.com/photo.php?v=423503517685105&set=vb.168572583180170&type=3&theater
tmdry
Bill Martins
Our prices for stairs are within Lorens.
We use a 36 inch S bend w/ 10 inch head.
Barry-QDCC
Barry Rhoads
I am $40 per room for the first 6 rooms. $30 each additional. Stairs are $45 - includes 13-15 steps.
I started out back in 1994 at $25 for a set of stairs.
Barry-QDCC
Barry Rhoads
I should add that I've timed myself and found a "normal" width of 14 steps takes me about 15 minutes. So I can't bitch at $180 or so an hour.
We just use the vac hose, for agitation either a brush or the makita 9227c with a hogs hair.
Reactions: tmdry
Hose cuff to vacuum, hydroforce to prespray, spotting brush on the bullnose.
Vivers
Bill
Typically $50 for normal size staircase. Double wide or heavily soiled extra of course. Works out to $3 per stair usually
.50 for HWE with a wand. No charge for scrubbing or spots
Small jobs we'll charge .55 or 60 for Rotary Extraction
.30 for Cimex with a .5 break for over 10k feet which does not exist here.
$85 for 13 steps, $95 for reverse or large landings.
Barry-QDCC
Barry Rhoads
BradFenstermaker
It's an area charge for us but need to jump $5-10 atleast.
Saigers Stair tool is the economy stair tool at JonDon.
Pretty sure it's a PMF Tool. I have loved mine for Years. Never tried the swivel head style
Yep, PMF stair stool, but I had it made into 2 jets instead of one jet.
Found the sweet spot with the jets in the pics.
We do like the swivel for steps....but nothing else!
John Olson has set them up for me.
Goomer
Frank Mendo
Thanks mark.
Most longer stair tools seem to be around 30 inches, which would be a big improvement over my 18 incher.........
The extra length should be enough to keep me upright and save my back somewhat.
Regarding either straight of S-bend, I am assuming the S-bend will have an advantage ergonomically on the bullnose, and will offer more clearance to reach the lower part on the bullnose curve, and flush it more efficiently.
So what's the vote on straight or s-bend???
Thanks mark.
We prefer the S bend.
It just ended up being very comfortable for us.
I miss my UT 40. Mike Palmer of HM showed it to me 30 years ago. It was similar to the one Willy pictured, but less angle on the head. I remember it being more similar to the current hydra hoe.
I think I still have a couple laying around in the bone yard, they are missing the valve though. I liked them for the period but I was never thrill with the air leaking from the edges. When Prochem came out with their stair tool we switched all of them out.
Willy P
Willy P
Can you do the entire bullnose and risers with the 40incher?....or do you switch to the shorty?
I flood the nose and spray the riser - not usually much more than a bit of dust on the riser. Open hose it to pick up the water.
End result:
GCCLee
C. Lee
Send me one to play wit ........
Pappa : )
