Michael and Dan;
You are giving out incorrect information ! (Many times the internet is NOT up to date)
Hopefully Dirk has received better info ??
Since temps in Vans now are quite hot, this is the correct info from Kohler:
If your TM manufacturer is not insisting on using 20W50 oil,
your engine life is at risk over 50' F.
Kohler recently changed the oil viscosity specs . . .
right after a MB member accused us of causing a main bearing failure.
Also automotive oils have
decreased the zinc content to prolong catalytic life (per the EPA).
This causes MORE wear in our TM engines.
We carry 20W50 oil , with the additional zinc.
Larry
