They don't make them anymore.
That don't sound good.I'll see if it helps any of the oil seepage through all the gaskets, the lifter noise and oil consumption in my 38hp Kohler.
A new Nissan? Where did you get the motor?We have a new TM with the Nissan 4-cyl engine and #59 blower . . .
Just bought a case of the 20W50
It will !
Yeah, like one. How long you gonna keep trying to hawk that Vawter-new 860 before you scrap it?They are still available in limited numbers.
Larry
Here is the Kohler info on "any hard working commercial operation" . . .
on use of the new 20-50W oil with additive package ;
While it was developed for the 34 to 40 HP engines, the factory regional service instructor recommends for all carpet cleaning TM applications.
Larry
Dan if you would ask them life expectancy with a duty load of what most cleaners will experience, 4-6 hours daily.
8200 on my 800A A 12 Nissan sold, 6400 on my 405 A 12 in trailer back, never use, 4400 on 650 Hyundai so far. I will never buy air cooled engine!
Jon Uber Technical Support Manager Loftin Equipment Co. | www.loftinequip.com Phone: (602) 272-9466 x 224 E-mail: juber@loftinequip.com |
I have tried 3-4 differnet brands od full syntheticKohler 20HP motor with 100 hours.
Is there any reason not to switch over to full synthetic right now?
Those air cooled engines are rated at so many 0000000.... Rpms in the life of the engineWell, apparently there is no clear-cut answer, as you will see. In asking the question, I found the person I was talking to has a much better understanding of truckmounts than I realized....
Here was my question:
Jon,
Thanks very much for the info!
I have another question, if you don’t mind. I realize the answer will be pretty subjective, so I won’t hold you to it….
The application is carpet cleaning machines (Truckmounts). Most machines use engines from 20hp to 37hp. Typically they are loaded to around 80% of rated capacity, and are run 4 to 6 hours a day, 5 or 6 days a week. RPM is 3000-ish to 3600. They are almost always mounted inside a van or trailer, operated with the vehicle door(s) open, so oil temps run on the high side of normal. Oil and filter is religiously changed per factory-recommended intervals for the vast majority of users.
The question is what engine life would one expect under these circumstances. Many in our group report engine replacement at around 2500 hours, while a few report much better life, 4000 hours or more.
We’re trying to determine whether the 4000 hour motors are just flukes, or if that should be the expected norm, and everyone else is doing something wrong, like maybe insufficient cooling.
A side question is whether adding an external oil cooler kit (for those engines that don’t already have one) would extend engine life significantly.
Is there anything else we could do to help extend engine life?
The questions were spawned due to one of our users having to replace a CH-20 at around 2000 hours. Some users feel that is to be expected, while others feel it is way too soon.
Any input you have would be appreciated!
Dan Gardner
Mobil 1...lasted 50 hours
Racing Oil
- What are the benefits to using a racing oil versus a regular "street legal" oil?
The Valvoline VR1 Racing & "Not Street Legal" racing oils contain additional additives for increased horsepower and reduced friction on metal parts, provide extra wear protection for high compression/higher horsepower engines, and include fewer detergents than regular conventional motor oils.- What is motor oil with zinc?
The anti-wear additive simply referred to as zinc by most car enthusiasts is actually short for Zinc DialkylDithiophosphates or ZDDP. Its primary role is to prevent metal-to-metal contact between engine parts by forming a protective film. Despite being referred to as zinc, this additive actually contains zinc and phosphorus, with phosphorus performing the anti-wear function in the motor oil with zinc.- Why is it important to have the zinc/phosphorus levels in motor oil changed?
With ever increasing limits on emissions, automobile manufacturers have tightened emission control systems on newer vehicles. This is one of several factors considered when the American Petroleum Institute (API) sets standards for motor oil with zinc. The current API standard is SM which replaced the previous SL classification. Because phosphorus can poison a vehicle's emission system, the level of zinc is lower for current motor oil.- What is the controversy surrounding the amount of zinc in motor oil?
Many hands-on car enthusiasts and engine experts believe the lower levels of zinc in SM motor oil is causing excessive wear in older style push-rod and flat-tappet engines. This is despite the fact that all new motor oil classifications are intended to be backward compatible. This has resulted in the widely accepted belief that modern motor oil is not adequate to protect older engines.- What solutions does Valvoline offer to the zinc issue?
Valvoline offers two solutions to the zinc issue:
- Valvoline VR1 Racing Oil: Contains 75% higher zinc than SM motor oil with a balanced additive package designed to work in both racing and street-legal applications. This product will protect older style push-rod and flat tappet engines. Valvoline provides this product in both multi and mono viscosity grades: 20w50, straight 50, 10w30, straight 30, straight 40, and straight 60.
- Longer-Lasting Zinc/Phosphorus: Valvoline uses an advanced zinc/phosphorus additive that keeps higher levels of phosphorus in the motor oil where it protects the engine instead of poisoning the catalytic converter. Valvoline is the only brand offering this unique additive across its entire line of passenger car motor oils including SynPower -- the only synthetic oil that offers this additive.
- Which oil has more zinc/ZDDP: VR1 or "Not Street Legal" racing oil?
Valvoline VR1 Racing Oil contains .13 percent of zinc and .12 percent of phosphorus compared to the Valvoline "Not Street Legal" Racing Oil which contains .14 percent of zinc and .13 percent of phosphorus.- Will an additive boost the zinc level?
You can use an additive to increase the zinc level. However, check with your motor oil manufacturer to ensure the additive is compatible with your racing oil.- Is VR1 a conventional oil, a synthetic or a blend?
Valvoline VR1 racing oil is a conventional, non-synthetic racing oil.
