360i clicking
Vivers
Bill
Mine is doing this to and it's located in the motor and I'm sending out tomorrow to be repaired
Back to Rotovac I suppose.
Do you have a small motor repair shop in town?
M
Mike Draper
When the original rotovav 360 came out I must have broke around 3 sets of gears. Each time I sent the motor back it was around $350-400ish. I finally said enough and bought a new gear for 40 bucks from them. Took the gear case apart and put it back together. It's really not that hard at all. Took 45 minutes.
M
Mike Draper
Rotovac just sends out a new refurbished replacement. Then they fix yours or refurbish it and send it out to the next guy with broken gears.
$40.00 and time is not a bad repair but damn $350.00-$400.00 that's tough to swallow.
Not Rotovac's fault, they didn't damage the gears but ouch!!! I need to remind the guys about vent covers.
Don't hit them. You not only risk damaging the gears but also the vent cover.
T
tcampbell1215
Iv got bump caps and do try to avoid them anyway but was unaware it could damage gears
M
Mike Draper
I think there are 3 gears if I remember correctly. If u are going to attempt to fix your self take it apart first and see what is broken.
T
tcampbell1215
Probably order a new one anyway and ill fix the other one anything else that usually breaks on these machines
John Olson
John Olson
its the top hat gear. They are part number B-2314H and are $45 plus shipping. We have them in stock and it's a common problem when you hit floor registers. How do you fix that problem ? Don't hit floor registers :)
Bad design if it doesn't have a shear pin.
That's why any well designed machine protects expensive delicate parts with easily replaced inexpensive parts.
I agree but even if it sheered, you would probably still damage the register. I stay a few inches away from them along with transitions, especially marble and stone ones.
Reactions: GCCLee
Scott S.
Scott
Hoss with rounded teflon glides :)
Or just wand around the edges and obstacles, and use it on the open area like the rest of us do
T
tcampbell1215
Well hear was the problem
John Olson
John Olson
that's the top hat gear. $45 and priority shipping 2 day USPS is $5.99
