Fuel tap question on truckmount
TimM
Tim Magaw
I ran my machine for a few hours today and ran fine. Finished the job and went to my next one. Machine started but died. Troubleshooted it down to not getting fuel. I swapped out the fuel pump and filter but still nothing. Is there a filter in the fuel tank on the fuel tap?
mirf
David Mirfin
Are you sure there is enough gas it tank to reach fuel tap line?
Shawn Forsythe
Properly installed, the tap line will reach to about 1/4 tank only, leaving you enough fuel to drive to a gas station.
Ordinarily there is no screen or filter actually in the tank for the TM tap.
Reactions: TimM
TimM
Tim Magaw
This is on a machine that Interlink installed back in 2005. So I would hope it was installed properly. I have owned the machine since 2007 and it has always worked and no issues with the fuel.
If the new pump is sucking then you'll need to check the pickup line for debris clogging it.
dgardner
Dan Gardner
Electric pump, or mechanical? Carbureted, or fuel injected (the TM, not the van)?
Have you tried to see if the pump will pull fuel (and run the TM) out of a gas can? That would help you see whether the issue was the fuel tap or something else.
Shane T
Shane Tiegs
If you are sure its a fuel problem, have you tried priming the pump?
I have a Facet pump under the van hooked to my 405.
When you turn the key to the ON position you can see the big red light flicker if the pump is running (you can hear it too).
I have a clear fuel filter in a visible spot to verify delivery, a pressure gauge as well (soon as I hook it up). It's also easy to pull the line off to verify.
Be DARN sure to reattach it securely to avoid the cover of the Bane Digest.
rwcarpet
Robert Hodge
My new Thermalwave install will run out at a hair over 1/4 tank....on level ground. Any angle will run it out sooner. So I just keep it full.
dgardner
Dan Gardner
It ended up being a section of hose was sucking air before the pump. I put a new filter and saw the crack in the hose and replaced that and it is running now.
If the line before the pump was brittle enough to crack, the line after the pump may be as well, and a cracked fuel line under pressure will ruin your day! Hope you replaced all of it....
