- Oct 6, 2006
- 117,066
Exactly
3 or 4 times a week someone was always saying how great the old powermax smelt...a clean fresh smell....one person liked the fruit slice....
smell is important as how well it cleans......if they notice it and it smells clean and fresh.....they are much more happy then some chemical smell or some off the wall fruity smell.......
not busting your balls Larry....I stand behind a lot of your stuff.......but you made a huge mistake changing it..........
The fruit slice is a nice smell but gets old fast. To sweet, like pouring syrup over candy. The old smell is way better.
i just knew you would come around.
this should be jim martin approved in no time!
Im not new to carpet cleaning, but am new to HWE and have researched and researched different presprays out there to suit my needs. I deal with apts all day, every day, some are great, but I have some that a match and a dab of gasoline would give a major improvement. From what I have read from everyone, Powermax is great and would like to try it out. Does Cobb's send out small samples to try out?
Just order a jar, it's only $20 , should make your job of cleaning trashed apartments easier. Remember to ignore the dilution instructions on the label,
Your waste tank must be small or have a lot of turbulence inside it causing it to foam.
I have never experienced any foaming issues in the tank with PowerMax. and I run 3 cups (24) ounces in a 1:8 hydro.
Whenever I pop my waste tank lid all that is in there is water, no foam.
And I use soft water in my fresh tank with detergent in it.
Hey Larry, just finished cleaning 2 large pre kindergarten rooms of totally trashed olefin glue down with your Powermax pre-spray at 3 oz. per gallon in a pump up sprayer. Extracted with End Zone. Powermax mixed well and worked like a champ! No foam issues either. Lots of dry strokes and speed dried with airmovers, as it should be, and I am now hooked on Powermax. Thanks for a wonderful product!
