- Oct 7, 2006
- 50,038
Yes, and happily so!
I rarely use the genset. It would be counter productive to using electricity in the first place.as far as Bob, he keeps a 7ooo+ wt generator .
the few that have owned/run his units say a 5K gen won't get it.
If that's the case, I'm not sure how he "never" NEVER blows a breaker .
Maybe cause he runs off the gen 80+% of the time???
I recently sold a demo Savage system to Tim Hall.I'm not suggesting a good job can't be done with a porty, Ed
.exactly...which makes it much more efficient due to the ability to use higher flow and increased pressure.
Simply takes less time and effort.
Year in and year out, the increase in time/efficiency pays
.you're not suggesting your machine doesn't blow breakers, are you??
(do you, or have ever cleaned carpets in the field for a living?)
add the booster and heater ...now tell me you don't locate the breaker box before you start the job
I don't have an ax to grind, and I'm NOT anti-porty, I promise
But to suggest running 200ft from a porty in the van as fine and dandy, is misleading to those that don't know better.
and just because some of your custys do it, doesn't make it less so
So then at 200ft you are plugging in a 3rd power cord for the downline boosterI rarely use the genset. It would be counter productive to using electricity in the first place.
I have blown a few breakers in the past 10 years, but that is also rare, as long as you use electrical knowledge (understanding distribution) when plugging in.
I plug in 2 cords to two separate 15 amp circuits, use screaming hot LP for heat, run a 2" Greenhorn with #8 flow, and clean at the same speed as I do with our slide-in.
I get the same results as when using our slide-in, so using the ETM does not make me work slower.
With the APO, I never have to stop to dump a tank as long as I have water/chemical.
95% of our jobs are 100' or less. When the distance is over 150', I will use a downline booster.
This is a high production ETM that doesn't require a genset, or a dryer plug, or 4 vac motors, or 220V.
can't make Nashville, am trying for Vegas in the fall. Hopefully, he'll have one there. Until then, call me, sceptical.
Bob, my portable system is set up with 2 vacs in parallel through a manifold that allows each vac motor to develop its full cfm that is compressed into a 2 inch standpipe in the waste tank. I am using 13.5 amp 5.7's. I am using a pump similar to yours that gets me 500 psi at a 5 flow. I have room to add an auto pump out on the other vac. You were saying that you are using an 8 flow wand, what kind of pressure were you getting?I will be the first to agree that a #4 blower on a gasoline truckmount has great vacuum, even when running dual wands each at 200'. I have a Roots #4 slide-in and it kicks butt with a total of 400' out (200' per wand). If you think it takes at least a #5 blower to pull that off, that's only because no one else has decided to put a system such as this together. There are some tricks in setting it up right, but it's not hard to figure it out. I put this system together over 25 years ago, when virtually no one was running dual wands.
Getting back to the ETM - the ETM that I designed has strong vacuum at 200' with no booster, and with only 2 - 15 amp circuits running the vac system, the APO, and the 600 PSI pump. We use LP for heat on both our ETM and our slide-in with the #4 blower. Clear tube testing has shown one dry stroke with no more moisture coming into the tube, even if you take a second dry stroke.
Using an ETM should not compromise your production times!
Our ETM will allow you to clean just as fast and efficient as the slide-in's with a #4 blower, requiring no extra vac strokes. Our ETM has the vacs set up in parallel, and with the APO and a water connection, you can clean for hours without stopping. So, our ETM does NOT slow you down compared to a gasoline truckmount, as some have said. I even have an ETM that will run dual wands up to 200' on each wand, but it takes 5 cords. With the genset, I run 3 -15 amp cords from there, and 2 more form the house, for a quick setup and tear-down. This system uses a base vac unit with APO, and a downline booster closer to the house, or inside the garage, for each wand, hence plugging both boosters into the house since that's where the vacuum systems are.
The Honda genset we use has a 50 amp 220 VAC outlet, which feeds the special breaker and 110 VAC box. This box can handle 4 separate 20 amp circuits, but I have it set at 4 - 15 amp since our ETM does not need any 20 amp circuits.
As far as the dual wand cleaning, you can get so much more work done in a day when dual wanding residential or commercial. We have cleaned tile and carpet at the same time, or upholstery with tile or carpet.
