rwcarpet
- Dec 6, 2009
- 3,084
- Name
- Robert Hodge
Last job the day before, went out to the van to start shutting down, and found a nice little spray coming from the bottom "T" on this strainer block on the Thermalwave. Just replaced all the brass fittings because there were leaks. I figured that if I had to pull this thing apart, I might as well change and tape all the fittings. It's time consuming and a bitch to reach everything without a 3rd hand. I bought all new fittings from a Parker store, so they were good quality. Well, I had to change out the bottom "T" because it had a crack right in the middle. 4 bolts hold it on from the rear, very tight compartment. Fortuneatly, I only had to remove the 4 anchor bolts from the back, and pivot the whole assembly out far enough to replace the "T".
Bout an hour.
Bout an hour.
