What have we got here?... 2015 Sapphire Pro 1200 unveiled..
Engineers double checking and re checking their work to ensure proper performance.
BLewis
Billy Lewis
So when is it scheduled to be available?
Roden's handiwork has served our family well. Perhaps this will be the 405 of truck powered machines.
I really like the apparent improvement of fit and finish.
Sapphire would be well served by offering packages of shelving and such, similar to the Bethel's work pictured here in years past.
Zee
What I don't understand is this: why wouldn't they name it something like Pro1300 instead of the old name?? If it's all redone and redesigned it will be quite different and always be a cause of confusion when buying parts and the model year is overlooked. (mainly on the second hand market)
Bryan S. Bennett
Central Steamer Professional Carpet & Upholstery Cleaning
Looks good.
They need to reconfigure the location of the solution line reel, move it a little to the left. I can see some knuckle busting with that handle location.
Reactions: hogjowl
Looks good.
They need to reconfigure the location of the solution line wheel, move it a little to the left. I can see some knuckle busting with that handle location.
put a motor and a switch on it...if your going big...go all the way.......
Reactions: hogjowl
Shane T
Shane Tiegs
I assume the silencer is inside the van, I like the exhaust location. Also like the filter with both 2 & 2.5 ports but I wouldn't be running it without a Devastator.
Theres is also another screen filter in the waste tank.
And the blower protection filter as well.
Shane T
Shane Tiegs
Plenty of protection, but cleaning that little filter after every job would be a hassle. Empty the devastator once a day and never have to touch the little one.
I just put a knee high in my port and let the vacuum connection hold it in place...leave the basket in just in case for some reason it breaks....end of job..disconnect hose...take off lid and toss it in trash and your ready for the next one...no restrictions and very easy...helps keep equipment clean.....
