Paint stripper or floor finish stripper? Most paint strippers are used straight out the can and floor finish strippers are mixed with water. Either way, follow the instructions. I have just started a post about this so we can explain it to our customers before we start and to help educate my technicians to the proper sequence. First we will never tell a client that we can remove all traces of sealer and may need to recoat with floor finish or urethane when we done stripping. Ideally we only stone enhanced and or sealed. But there is no telling what is on a floor until you begin stripping it.
QUALIFY WITH THE CUSTOMER.
You will remove paint form baseboards and any splatter can leave marks on walls and appliances-
You cannot guarantee complete removal
Use a splashguard on your rotary scrubber
Charge by time and material- paint and urethane strippers are costly.
- First we apply floor stripper liberally and dilute according instructions on bottle.
- Allow to dwell 15-20 minutes, don't allow it to dry
- Scrub with stiff brush- and or black pads. Stopping pads work well on smooth surfaces and brushes work better in grout joints or uneven tile (slate).
- Extract and rinse off- spinner or tiles tools work the best.
- Inspect and repeat
- If there is another film left behind like polyurethane you will need to use a paint/ urethane stripper. They are more toxic and difficult to use.
- Wear a RESPIRATOR AND GLOVES!
- Apply to test area, (follow instructions on container)
- Dwell (follow instruction)
- Agitate with brush or scrape up or squeegee off the tile. You need a tool that won't scratch the tile and not dissolve from the paint stripper. Plastic squeegees will sometimes work if you must use metal putty knives be very careful.
- You will want to scrape the loosened mess up and into a bucket or garbage bags, most of these products are solvent based and won't rinse off with water.
- Wipe up remaining slurry and mess with disposable rags- old terry cloth work well.
- You can try to rinse remaining residue with Odorless mineral spirits and wipe it up.
- Inspects and repeat as necessary
