- Aug 9, 2012
- 11,504
- Name
- sam miller
Yeah your thermal valve is installed backward.thermal valve.............
So I just turn it around?
Pigsnot hard to blame Sapphire when it appears its a product causing the problem. Whether its the heat combined with those ingredients or the ingredients themselves. That stuff sounds like its going to give you fits until you quit using it.I don't understand why you Sapphire guys are asking these repair questions here? Are your distributors clueless?
Had Mitch look at the temp switch, the magic potion had blocked the out bound screen and left alot of white crap so he cleaned it all out said that was the problem.
Good grief. Who said ANYTHING about blaming Sapphire? You Sapphire shills are so sensitive.Pigsnot hard to blame Sapphire when it appears its a product causing the problem. Whether its the heat combined with those ingredients or the ingredients themselves. That stuff sounds like its going to give you fits until you quit using it.
The great news is that the machine is still cranking out the heat even with thermal valve dumping. That's impressive.
Gene
because I have to drive an hour each way in traffic that exceeds the population of your entire state!I don't understand why you Sapphire guys are asking these repair questions here? Are your distributors clueless? Can you not get help from them? Is your machine over a MONTH old and out of warranty? The first place I'd go for diagnostic help would be the place where I bought it.
The thermal valve was closed when I took if off this morning could blow through it.
You could pick up the phone and call your distributor. They are there to help you.B
