- Mar 24, 2009
- 3,547
- Name
- gene miller
I have some to clean at a country club in the dining room. I'm not a big fan of wool period but especially a dining room. I found this interesting from their site.
Rinse and Extract
The next step is rinsing the suspended soil out of the carpet, through extraction. Keep in mind that the best extractors only extract about 80 to 85% of the original solution put into the carpet. If it is left to dry, those detergents will cause re-soiling to occur. The chemical for this step should be an acidic or neutralizing rinse. While many people try water, it is not effective in removing the residues and soils from the pre-spray. Rinsing with hard water will only remove about 15% of the residue, and rinsing with soft water will only remove 30%. But rinsing with an acidic or neutralizing rinse will remove over 90% of the residue.
Full article if you want to read.
http://crossleyax.com/Downloads/Maintenance_Info_Crossley_Axminster_100227.pdf
Multiple times they print in big bold letters
DO NOT USE ROTARY SHAMPOO OR SPIN BONNET ABSORBENT PAD ON WOOL OR WOOL/BLEND CARPETS – EVER.
Gene
Rinse and Extract
Gene
